Forum Software Ferduino code PCF8575 problem code
PCF8575 problem code  [SOLVED]
Post Number:#1 Post Sat Apr 23, 2016 8:48 am
Hi fernando , first of all thank you for this great project. I 'm connecting the pcf8575 and the post you say how to make changes in the code the link does not work.
viewtopic.php?f=24&t=71&p=346&hilit=pcf8575&sid=8c555a0d1e3d4dbe400ebf8a6d5ef8af#p346
Can you tell me what you have to comment or uncomment ??
Post Number:#2 Post Sat Apr 23, 2016 11:02 am
Welcome Raul!
The new code available on Github is ready to work with PCF8575, no changes is required.
Firstly you should test using an example available on forum to make sure that circuit is ok.
Post Number:#3 Post Sun Apr 24, 2016 3:24 pm
Hi fernando , thanks for the reply I have it working. What happened is that there had connected the pins 20-21 and the TFT screen was bright white.
Greetings and thanks.
