Hi all,
I'm reviewing the operation of the necessary parts for my controller , even the W5100 ethernet , i loading the last version of the Ferduino Web Control to my MEGA 2560 but It does not work in the network...
I have just connected the module arduino and W5100 , to prevent further complications
and then go connected the rest of the parts.
After some tests, it is likely that the libraries that are included with the code , are not correct, or i'll missing something.
I followed these instructions
viewtopic.php?f=24&t=36
viewtopic.php?f=8&t=266
just for a reference...
if I charge the mega code 2560 and connect the module W5100 together with the adjustments mentioned in the tutorial (viewtopic.php?f=8&t=34) , you should obtain a reply and should work without need to connect the rest of the part???
so sorry for the stupid questions , but I would like to properly understand the controller.
Best Regards.
