Forum Software Ferduino code Touch screen inverted
Touch screen inverted  [SOLVED]
Post Number:#1 Post Fri Jan 22, 2016 2:22 pm
Belgium
Hello Fernando,
I installed your last version of Ferduino and IDE 1.6.7 but since the installation its impossible to use the touch screen, it looks like it was mirrored.I have searched everywhere I could in the forum or on google but I can't find a solution.
i was hoping that the last version of yesterday would solve my problem but I just finished installing it and the problem is the same.
Have you an idea of what could cause this problem as no changes were made to my installation and everything works correctly before except web control but only because I had problem with my network.
Thanks in advance
Jean-Yves
Post Number:#2 Post Fri Jan 22, 2016 2:36 pm
The coordinates in UTouchCD.h were edited?
You was using this method before?
viewtopic.php?p=793#p793
Post Number:#3 Post Fri Jan 22, 2016 2:45 pm
Belgium
Fernando,
I do not use this method because I never had problem before.
Yesterday I tried the test code but I only had access to the main screen and the touch was not responding.
Post Number:#4 Post Fri Jan 22, 2016 2:48 pm
Post Number:#5 Post Fri Jan 22, 2016 3:09 pm
Belgium
This is what I have just done and now everything looks OK.
I don't know why I had problem yesterday otherwise I would not have disturb you with stupid question :)
Even if it's not the right topic, could you tell me if we choose DHCP we still have to use an IP address in the code (byte IP lign 604 ?
I am trying to use the webserver function but I am not a specialist in network;
Thanks again
Jean-Yves
Post Number:#6 Post Fri Jan 22, 2016 3:28 pm
After select DHCP this line will be useless.
byte ip[] = {192, 168, 0, 177};
Since that initial issue was solved the topic will be closed. To any other question please create a new topic.
