I am somewhat new to arduino programming. I have learned a lot just by using this website. I am using the ferduino mega and the english source code. I am having problems with compiling the code to use the PCF8575. I have followed the instructions on this topic link viewtopic.php?p=346#p346 . Can someone help me and point out where I have the problem. I will show here everything i have changed.
My error message
Code: Select all
Parametros.ino: In function 'void checkTempC()':
Parametros:42: error: expected unqualified-id before '.' token
Parametros:56: error: expected unqualified-id before '.' token
Parametros:64: error: expected unqualified-id before '.' token
Parametros:72: error: expected unqualified-id before '.' token
Parametros.ino: In function 'void reposicao_agua_doce()':
Parametros:224: error: expected unqualified-id before '.' token
Parametros:229: error: expected unqualified-id before '.' token
Temporizadores.ino: In function 'void check_temporizadores()':
Temporizadores:10: error: expected unqualified-id before '.' token
Temporizadores:15: error: expected unqualified-id before '.' token
Temporizadores:23: error: expected unqualified-id before '.' token
Temporizadores:29: error: expected unqualified-id before '.' token
Temporizadores:34: error: expected unqualified-id before '.' token
Temporizadores:41: error: expected unqualified-id before '.' token
Temporizadores:51: error: expected unqualified-id before '.' token
Temporizadores:56: error: expected unqualified-id before '.' token
Temporizadores:64: error: expected unqualified-id before '.' token
Temporizadores:70: error: expected unqualified-id before '.' token
Temporizadores:75: error: expected unqualified-id before '.' token
Temporizadores:82: error: expected unqualified-id before '.' token
Temporizadores:92: error: expected unqualified-id before '.' token
Temporizadores:97: error: expected unqualified-id before '.' token
Temporizadores:105: error: expected unqualified-id before '.' token
Temporizadores:111: error: expected unqualified-id before '.' token
Temporizadores:116: error: expected unqualified-id before '.' token
Temporizadores:123: error: expected unqualified-id before '.' token
Temporizadores:133: error: expected unqualified-id before '.' token
Temporizadores:138: error: expected unqualified-id before '.' token
Temporizadores:146: error: expected unqualified-id before '.' token
Temporizadores:152: error: expected unqualified-id before '.' token
Temporizadores:157: error: expected unqualified-id before '.' token
Temporizadores:164: error: expected unqualified-id before '.' token
Temporizadores:174: error: expected unqualified-id before '.' token
Temporizadores:179: error: expected unqualified-id before '.' token
Temporizadores:187: error: expected unqualified-id before '.' token
Temporizadores:193: error: expected unqualified-id before '.' token
Temporizadores:198: error: expected unqualified-id before '.' token
Temporizadores:205: error: expected unqualified-id before '.' token
Ferduino Tab changes
Code: Select all
#include <avr/pgmspace.h>
#include <PCF8575.h>
Code: Select all
///**************** PCF8575TS **********************************
const byte temporizador1 = 0; // P0 // Pino que liga o timer 1.
const byte temporizador2 = 1; // P1 // Pino que liga o timer 2.
const byte temporizador3 = 2; // P2 // Pino que liga o timer 3.
const byte temporizador4 = 3; // P3 // Pino que liga o timer 4.
const byte temporizador5 = 4; // P4 // Pino que liga o timer 5.
const byte solenoide1Pin = 5; // P5 // Liga a reposicao de água doce.
const byte aquecedorPin = 6; // Pino que liga o aquecedor
Code: Select all
//************************** Variáveis do PCF8575 *****************************************
/*boolean PCF8575TS_S = True; // Altere para "false" caso não tenha um PCF8575
PCF8575 PCF8575TS;
byte endereco_PCF8575TS = 0x20; // Endereço em hexadecimal = 0x20
PCF8575 PCF8575TS;
parametros tab changes
changed all "digitalWrite(aquecedorPin" to "PCF8575.digitalWrite(aquecedorPin" like the code below i did for solenoide1pin
Code: Select all
PCF8575.digitalWrite(solenoide1Pin,HIGH);
bitWrite(Status,1,1); //sinaliza reposição em andamento
PCF8575.digitalWrite(solenoide1Pin,LOW);
bitWrite(Status,1,0); // sinaliza reposição em andamento
I have also changed temporizadores tab codes from "digitalWrite(temporizador" to "PCF8575.digitalWrite(temporizador"
setup tab changes
I am not not sure if i need to do anything with this section below
Code: Select all
/* if(PCF8575TS_S == true)
PCF8575TS.begin(endereco_PCF8575TS); // Inicia a comunicação com o PCF8575TS
for(int i = 0; i < 16; i++)
PCF8575TS.pinMode(i, OUTPUT);
delay(100);
PCF8575TS.digitalWrite(i, LOW);
Code: Select all
//**************** PCF8575 ****************
pinMode (temporizador1, OUTPUT); // Pino 80;
pinMode (temporizador2, OUTPUT); // Pino 81;
pinMode (temporizador3, OUTPUT); // Pino 82;
pinMode (temporizador4, OUTPUT); // Pino 83;
pinMode (temporizador5, OUTPUT); // Pino 84;
pinMode (solenoide1Pin, OUTPUT); // Pino 85;
pinMode(aquecedorPin, OUTPUT); // Pino 42;
