Forum Software Ferduino code Led moon minimum
Led moon minimum
Post Number:#1 Post Sat Jul 11, 2015 5:07 pm
Topics: 22
Topics: 22
Post Number:#2 Post Sun Jul 12, 2015 6:56 am
Topics: 22
Topics: 22
sorry but I do not know how you can edit a post
I wanted to also ask how can I do so that day the moon led is off
I modified this way but does not work
 float lunarCycle = moonPhase(t.year, t.mon, t.date); //get a value for the lunar cycle
  moonled_out = MinI *(1 - lunarCycle) + MaxI * lunarCycle + 0.5;// * reduzir;
  if ((bled_out != 0) && (wled_out != 0) && (rbled_out != 0) && (rled_out != 0) && (uvled_out != 0));
    moon_out = 0;
  if ((bled_out == 0) && (wled_out == 0) && (rbled_out == 0) && (rled_out == 0) && (uvled_out == 0));
    moon_out = moonled_out;
  if (MeanWell == true)
    b_out = bled_out;
    w_out = wled_out;
    rb_out = rbled_out;
    r_out = rled_out;
    uv_out = uvled_out;
    //moon_out = moonled_out;
    b_out = (255 - bled_out);
    w_out = (255 - wled_out);
    rb_out = (255 - rbled_out);
    r_out = (255 - rled_out);
    uv_out = (255 - uvled_out);
    //moon_out = (255 - moonled_out);
  if(suavizar < 1)
    b_out = suavizar * b_out;
    w_out = suavizar * w_out;
    rb_out = suavizar * rb_out;
    r_out = suavizar * r_out;
    uv_out = suavizar * uv_out;
    moon_out = suavizar * moon_out;
  analogWrite(ledPinBlue, b_out);
  analogWrite(ledPinWhite, w_out);
  analogWrite(ledPinRoyBlue, rb_out);
  analogWrite(ledPinRed, r_out);
  analogWrite(ledPinUV, uv_out);
  analogWrite(ledPinMoon, moon_out);
Post Number:#3 Post Mon Jul 13, 2015 1:23 pm
Are you trying to turn off the moon light during the day?
Post Number:#4 Post Mon Jul 13, 2015 3:50 pm
Topics: 22
Topics: 22
Post Number:#5 Post Mon Jul 13, 2015 4:16 pm
Try this:
Find:
Replace with:
  if((b_out > 30) && (w_out > 30) && (rb_out > 30) && (r_out > 30) && (uv_out > 30)
   analogWrite(ledPinMoon, 0);
I think better to use a value less than 30 because if all lights are off when the moon light turn on will give a "flash". Mainly in full moon.
Last edited by Fernando Garcia on Mon Jul 13, 2015 4:24 pm, edited 1 time in total.
Reason: Code fixed
Post Number:#6 Post Tue Jul 14, 2015 3:15 am
Topics: 22
Topics: 22
Post Number:#7 Post Tue Jul 14, 2015 5:17 pm
To new moon (lunarCycle = 0) the variable "moonled_out" should be zero to this code:
Maybe you need add a resistor (pull down) of 10K between PWM and GND.
Post Number:#9 Post Sun Jul 26, 2015 3:03 pm
Replace this 47K by 10K.
