Forum Software Ferduino code Problem to install ferduino with web control
Problem to install ferduino with web control  [SOLVED]
Post Number:#1 Post Mon Jun 08, 2015 7:58 pm
Topics: 8
Images: 10
Topics: 8
Hi, I am unable to install ferduino with web control. I downloaded the latest version on github, compiles normally but when you run is the message in the LCD: "Please insert a SD CARD".
I have already put the card into the slot LCD, the ethernet shield W5100 and is always presenting this message. What can be?
I appreciate the help.
Excuse my English, I'm using google translate. :)
Post Number:#2 Post Mon Jun 08, 2015 11:13 pm
Welcome Antonino!
Did you the bridge between pin 4 and R16 as explained here?
The ethernet shield is connected as explained here?
Post Number:#3 Post Tue Jun 09, 2015 7:10 am
Topics: 8
Images: 10
Topics: 8
Thank you Fernando, I forgot these procedures, I will do this and give the return.
Pin 4 connected to the R16, the R16 I drop a tip of his board?
Post Number:#4 Post Tue Jun 09, 2015 7:37 pm
Topics: 8
Images: 10
Topics: 8
Fernando, did the procedures indicated me only now when I turn on the LCD is on the screen to enter the password but the touch is not working.
I was with out a doubt, the bridge pin-4 to R 16, the bridge is to stay in the resistor or on the board?
Tank you.
Post Number:#5 Post Tue Jun 09, 2015 8:16 pm
You need CUT or NOT weld the side of the resistor that goes to pin 53.
Post Number:#6 Post Wed Jun 10, 2015 10:05 am
Topics: 8
Images: 10
Topics: 8
The following pictures of how I made the connections, the LCD is on the password screen and the touch is not working.
youtube a video of the operation
tank you
Post Number:#7 Post Wed Jun 10, 2015 10:33 am
Are you using this line on code?
UTouch      myTouch(6,5,4,3,2);
Post Number:#8 Post Wed Jun 10, 2015 1:02 pm
Topics: 8
Images: 10
Topics: 8
Fernando, I made the change in code, which is only now appearing to "Please insert the SD CARD" message. What can be now?
When the code is uTouch myTouch (7,6,5,4,3); , The touch does not work and is on the password screen, when I change to uTouch myTouch (6,5,4,3,2); is requesting the card.
I put the memory card in both the LCD and in the ethernet shield W5100.
What can be now?
Thank you.
Use this line:
const byte ChipSelect_SD = 4;
Post Number:#10 Post Wed Jun 10, 2015 6:26 pm
Topics: 8
Images: 10
Topics: 8
Hello Fernando, now it worked, but now the date and time are not displayed. It presents xxxxxxxx0 of 2000 xxxxxxx 00:00:85
How to fix it?
I've been in the time and date menu, adjust but not working.
Thanks again for your help.
Post Number:#11 Post Wed Jun 10, 2015 6:38 pm
This questions are very basic and have answers on forum already.
Use this line:
DS1307 rtc(20, 21);
