Forum Software Ferduino code Problem with ethernet module ENC28J60 (dont ping)
Problem with ethernet module ENC28J60 (dont ping)  [SOLVED]
Post Number:#1 Post Mon May 11, 2015 5:49 pm
I uploaded a code ferduino and tested ping but no have a return, i have a tft display with sd card and i make a bridge of R16 to pin4, after i uploaded a code test ENC28J60 "Ethernet shield with ENC28J60" from http://www.ferduino.com/forum/viewtopic.php?f=8&t=42 and tested ping and have return.
with the test code works, but with the code ferduino not, can anyone give a hint?
all test ping in local network
man did a search found nothing, sorry if I let it go.
Thx
Post Number:#2 Post Mon May 11, 2015 6:09 pm
Belgium
Hello,
In Ferduino code "Funções do ethernet shield" did you change false to true for "boolean Ethernet_Shield"
Best regards,
Jean-Yves
Post Number:#3 Post Mon May 11, 2015 6:15 pm
Hello,
Best regards,
Jean-Yves
Hi Jean,
already true.
Post Number:#4 Post Mon May 11, 2015 6:38 pm
Belgium
Sorry then
Can't help you.
Jean-Yves
Post Number:#6 Post Mon May 11, 2015 10:31 pm
http://www.ferduino.com/forum/viewtopic.php?f=20&t=82
thx Fernando I Will buy a module w5100.
