Forum Software Ferduino code Installation problem
Installation problem  [SOLVED]
Post Number:#1 Post Tue Jan 20, 2015 6:24 pm
Hungary
Dear All,
I am very happy to be here!
I have problem with this:
Feduino_with_webcontrol_beta.ino:437:21: error: too many decimal points in number
I really do not know what could it be and how to resolve it. I think I have tried everything..
If I write it to wrong place I am sorry!
Thank you for your ideas!
Post Number:#2 Post Tue Jan 20, 2015 6:38 pm
Welcome Istvan!
You are using dots instead comma for IP address.
I found this type of error very fast using the google without look your code.
Second result: http://bit.ly/155xYcD
Post Number:#3 Post Tue Jan 20, 2015 6:47 pm
Hungary
Welcome Istvan!
Thank you! You are genius!! Dot was my habit... and it was enough to take to one place. :-bd
I have hungarian language version! How can I upload it to share with others?
Can I send it via e-mail?
Now I have another mistake: I did what installation said but I have problem:
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:632: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:633: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:634: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:635: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:636: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:637: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:638: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:639: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:641: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:642: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:643: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:644: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:645: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:646: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:647: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:648: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:649: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:650: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:651: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:652: error: stray '\240' in program
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp: In member function 'uint8_t DS1307::_readRegister(uint8_t)':
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:468: error: a function-definition is not allowed here before '{' token
D:\Users\Big-pc\Documents\Arduino\libraries\DS1307henning\DS1307.cpp:653: error: expected `}' at end of input
In the file I modified everything what installation contains.
Last edited by Fernando Garcia on Tue Jan 20, 2015 9:22 pm, edited 1 time in total.
Reason: Please use tags [code] [/code] to post any code.
Post Number:#4 Post Tue Jan 20, 2015 9:34 pm
Send me the translation by private message please.
Check all changes that you did in the library especially on this part:
https://github.com/FernandoGarcia/Ferdu ... 7.cpp#L296
And changes to add "getTimeStamp" function to DS1307.cpp.
Follow the tutorial available on forum.
Post Number:#5 Post Wed Jan 21, 2015 3:35 pm
Hungary
Thank you, every settings works all right! :-bd
But I can't reach the device. There is not in DHCP clients list. It doesn't want to reply to PING.
byte mac[] = {0x55, 0x90, 0x10, 0x2E, 0x20, 0x0E }; // Este MAC deve ser único na sua rede local.
byte ip[] = {192, 168, 2, 8};                     // Configure o IP conforme a sua rede local.
IPAddress dnsServer(84, 3, 129, 234);                    // Configure o IP conforme a sua rede local. Este é o DNS do Google, geralmente não é necessário mudar.
IPAddress gateway(192, 168, 2, 1);                  // Configure o "Gateway" conforme a sua rede local.
IPAddress subnet(255, 255, 255, 0);                 // Configure a máscara de rede conforme a sua rede local.
EthernetServer server(80);
I tried with various port number too..
Last edited by Fernando Garcia on Wed Jan 21, 2015 4:36 pm, edited 1 time in total.
Reason: Please use tags [code] [/code] to post any code here.
Post Number:#6 Post Wed Jan 21, 2015 4:39 pm
Please use tags to post any code here.
Check the wiring and use a code for test first.
Post Number:#7 Post Wed Jan 21, 2015 5:06 pm
Hungary
I tried it.. I checked the wires but in the router it does not appear DHCP like device.
Can the device be wrong? (w5100) Is it normal that the 2 green leds blinking few times?
