Forum Software Ferduino code Error with new web code
Error with new web code  [SOLVED]
Post Number:#1 Post Fri Dec 12, 2014 5:11 pm
I am getting this error when I try to upload new joy reef code.
 Webserver.ino: In function 'void processRequest()':
Webserver:11: error: 'class EthernetClient' has no member named 'getRemoteIP'
Post Number:#2 Post Fri Dec 12, 2014 7:01 pm
You did update of your ethernet library as explained here?
Post Number:#3 Post Sat Dec 13, 2014 3:51 am
Yes I had to load all new, I messed something up when I first started, do I have to old and new or just the new?
-------------------------------- Last edited Sat Dec 13, 2014 1:17 am --------------------------------
Post Number:#4 Post Sat Dec 13, 2014 8:54 am
This new ethernet library works with any code.
Post Number:#5 Post Sat Dec 13, 2014 9:03 am
Ok will try to correct when I get home from work. Thank you for your response.
-------------------------------- Last edited Sat Dec 13, 2014 6:03 am --------------------------------
Post Number:#6 Post Mon Dec 15, 2014 3:59 am
So at this point I am not working on web control any more, I need to get this controller on my tank and running. I took all the files off my pc loaded only the ones that I needed for ferduino english and web control and still couldn't get to show on my network, I tried all test codes, all types of configuration and nothing would work.
-------------------------------- Last edited Mon Dec 15, 2014 12:59 am --------------------------------
Post Number:#7 Post Mon Dec 15, 2014 9:41 am
You bought the SD card of 1 or 2 GB as I told in last time?
Ferduino_English isn't compatible with Ferduino Mega.
The code was done to the ethernet controller ENC28J60.
