Forum Software Ferduino code I need PCF8575 for use only 1 time relay?
I need PCF8575 for use only 1 time relay?  [SOLVED]
Post Number:#1 Post Wed Oct 15, 2014 4:48 pm
Topics: 9
Topics: 9
Hi again! ~x(
In my project i need only one time relay for ATS leds... same for only one time relay i will need PCF8575 or not?
Thx!
Post Number:#2 Post Wed Oct 15, 2014 11:16 pm
You can use any free pin.
The pin 7 is free and you can change the pins of functions that isn't needed for you.
Never use the same pin to 2 functions.
Post Number:#3 Post Thu Oct 16, 2014 10:00 am
Topics: 9
Topics: 9
Thanks Fernando,
I will check the possibilities, because it would not change much code and leave the original Ferduino possible when you need to expand the functions have no problem because of changes I made.
Post Number:#4 Post Fri Oct 17, 2014 10:32 am
Topics: 9
Topics: 9
Hi again,
If change in a code a pin for time relay, would be something like this?
EX_in_code:
// Pinos 22 à 41 reservados para o LCD.
const byte ozonizadorPin = 47;  // Pino que liga o ozonizador
const byte reatorPin = 48;      // Pino que liga o CO2 do reator.
const byte temporizador1 = 80;       // P0       // Pino que liga o timer 1.
const byte temporizador2 = 81;       // P1       // Pino que liga o timer 2.
and change a value 80 (time1) and 81(time2) to 47 and 48 from (ozonizadorPin,reatorPin)
or have to change more lines of code?
looking the code a pin 7 is reserved to touch
// Pinos 3, 4, 5, 6 e 7 reservados para o Touch.
taking advantage, will have a total of 6 relays, all are 5v, can connect directly to pin 5v with the mega temp sensors. or have to use an external source 5v?
I'm using the mega with a 10A 12v source and stepdown for 9v, is it right?
i will use the external source to the relay put another stepdown to 5v and linking the six relays?
1 relay to chiller
1 relay to heater
1 relay to time
3 relays to future expand
Thx
Last edited by Fernando Garcia on Fri Oct 17, 2014 6:29 pm, edited 1 time in total.
Reason: Added tags for code.
Post Number:#5 Post Fri Oct 17, 2014 6:28 pm
This way:
const byte ozonizadorPin = 80; // Pino que liga o ozonizador
const byte reatorPin = 81; // Pino que liga o CO2 do reator.
And:
const byte temporizador1 = 47; // P0 // Pino que liga o timer 1.
const byte temporizador2 = 48; // P1 // Pino que liga o timer 2.
(// Pinos 3, 4, 5, 6 e 7 reservados para o Touch.)
Pin 7 is used for touch on Ferduino Mega 2560.
Good option to not heat the Arduino much.
I think this option better.
