Forum Software Ferduino code Change in graph number
Change in graph number  [SOLVED]
Post Number:#1 Post Tue Jul 16, 2019 4:02 am
Indonesia
Hallo Fernando,
I have trouble changing the chart sequence number, please help, how to calculate this math, I tried it was not good.
this is the code that I use
void LedgrphScreen()//------------------------------------------------------------ tela =61
  int x, y, z, grafico;
  int16_t n;
  char buf[8];
  float temperatura;
  int j = 0;
  int i = 0;
  int k = 0;
  float soma = 0.0f; // Soma dos valores de todos os elementos
  float media = 0.0f; // Média dos valores
  float linhaR;
  int f = 30;
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[51])));
  printHeader("TEMP.LED GRAPHIC"); // "TEMP.WATER GRAPHIC"; // tabela_textos[51]
  setFont(SMALL, 255, 255, 255, 0, 0, 0);
  myGLCD.print("TEMP. LED NOW :", 5, 220);
  for (float i = 47; i > 25.0; i -= 2)
    myGLCD.printNumF(i, 1, 5, 3 + f);
    f += 15;
  f = 255;
  for (int i = 22; i > 0; i -= 2)
    myGLCD.printNumI(i, f, 193);
    f -= 20;
  myGLCD.print("0", 275, 193);
  myGLCD.drawCircle(15, 21, 2);
  myGLCD.print("C", 20, 18);
  myGLCD.print("H", 290, 193);
  myGLCD.drawLine(40, 30, 40, 190); // Eixo y
  myGLCD.drawLine(40, 190, 290, 190);  // Eixo x
  myGLCD.setColor(64, 64, 64);  // Malha
  //EIXO X
  for (int k = 30; k < 190; k += 7)
    myGLCD.drawLine(40, k, 290, k);
  //EIXO Y
  for (int l = 60; l < 300; l += 20)
    myGLCD.drawLine(l, 30, l, 190);
  linhaR = tempH;  //  Linhas de comparação
  if ((linhaR >= 27) && (linhaR <= 47))
    x = (190 - ((linhaR - 27) * 10));
  else if (linhaR > 47)
    x = 30;
  else if (linhaR < 27)
    x = 190;
  myGLCD.setColor(255, 0, 0);
  myGLCD.drawLine(40, x, 290, x);// Temperatura desejada
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[11])));
  printButton(buffer, iniC[0], iniC[1], iniC[2], iniC[3], false, 4);
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[1])));
  printButton(buffer, menU[0], menU[1], menU[2], menU[3]);
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[66])));
  printButton(buffer, prOK[0], prOK[1], prOK[2], prOK[3]);
  setFont(SMALL, 255, 255, 0, 0, 0, 0);
  myGLCD.printNumF(tempH, 2, 135, 220);  // LED
  int d = 41 + (NumMins(t.hour, t.min) / 6);
  myGLCD.drawLine(d, 30, d, 190); // Linha de marcação do horário.
  myGLCD.print(rtc.getTimeStr(FORMAT_SHORT), d + 2, 75, 270);
  selecionar_SPI(SD_CARD);
  if (file.open("LOGTLED.TXT", O_READ))
    while ((n = file.read(buf, sizeof(buf))) > 0)
      temperatura = atof(buf);
      soma += temperatura;
      if (strlen(buf) == 5)
        i++;
        k++;
      if (temperatura <= 2 )
        k -= 1;
      if (i == 6)
        media = soma / k;
        i = 0;
        j++;
        soma = 0;
        k = 0;
        if ((media) > 47)
          grafico = 30;
        else if ((media >= 27) && (media <= 47))
          grafico = (190 - ((media - 27) * 10));
          grafico = 190;
        setFont(SMALL, 204, 32, 255, 0, 0, 0);
        if (j < 250)
          myGLCD.drawPixel((40 + j), grafico);
          myGLCD.drawPixel((40 + j), (1 + grafico));
          myGLCD.drawPixel((41 + j), grafico);
          myGLCD.drawPixel((41 + j), (1 + grafico));
    file.close();
result images this code
thanks
Post Number:#2 Post Tue Jul 16, 2019 5:32 pm
Happy to know you are trying learning coding yet.
I don't think good idea make one line per degress in grid lines.
I think it should be:
  // EIXO X
  for (int k = 40; k < 180; k += 15)
For others line you have to adjust basically this equation.
or
    x = (190 - ((linhaR - 27) * multiplier));
x here is the y coordinate for red line. So you have to think what should be the multiplier to make x be 40 when linhaR is 47 or make x be 190 when linhaR is 27.
So you can make for linhaR = 47:
40 = (190 - (47 - 27) * multiplier)
40 = 190 - 20 multiplier
20 multiplier = 190 - 40
multiplier = 150 / 20
multiplier = 7.5
Just to make sure when linhaR is 47 x should be 40:
x = 190 - (47 -27) * 7.5
x = 190 - 20 * 7.5
x = 190 - 150
x = 40
Therefore the equation is:
x = (190 - ((linhaR - 27) * 7.5));
Let me know if it help you.
Post Number:#3 Post Wed Jul 17, 2019 10:57 pm
Indonesia
Thank you answered quickly and detailed explanation,
I am really happy for this. :-bd
thank you I will try, I will post the results here
thanks.
Post Number:#4 Post Tue Jul 30, 2019 4:22 pm
The problem was solved?
Post Number:#5 Post Thu Aug 01, 2019 6:40 am
Indonesia
sorry I haven't tried, this month I'm out of town, maybe next week I can try.
:-bd :-bd thank you
Post Number:#6 Post Wed Aug 07, 2019 7:39 pm
Indonesia
thank you, this went perfectly, as I expected
This problem solved.
