Forum Software Ferduino code Ferduino on 5'' tft problem resolution
Ferduino on 5'' tft problem resolution  [SOLVED]
Post Number:#1 Post Sun Feb 12, 2017 5:53 pm
Greece
hello fernando... sorry for my english isnt very good
i load the ferduino code to arduino mega. the touch works great. but i have problem with the resolution....
any help
Post Number:#2 Post Sun Feb 12, 2017 6:18 pm
Ferduino was done to a TFT with resolution of 400 x 240 therefore 1/4 of this size, so it's absolutely normal.
If do you want a full screen you should use a modified version.
The latest modified version was done by Mattia, the topic is here: viewtopic.php?f=8&t=399
The code is here: https://github.com/Wolfire18/Ferduino_800x480res
As I told here if you are going to use a modified version you should ask for help for MOD author on Github.
https://github.com/Wolfire18/Ferduino_800x480res/issues
Last edited by Fernando Garcia on Sun Feb 12, 2017 7:41 pm, edited 1 time in total.
Reason: Fix user name.
Post Number:#3 Post Mon Feb 13, 2017 7:16 am
Greece
hi...
i try today to load the new code for big tft 800x240
i change some librarys and problems with fonts..
now i receive one error for the time...
Arduino: 1.8.1 (Windows 10), Πλακέτα:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\libraries\UTFT\BigFont.c:21:14: error: variable 'BigFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 fontdatatype BigFont[3044] PROGMEM={
exit status 1
Σφάλμα μεταγλώττισης για την πλακέτα Arduino/Genuino Mega or Mega 2560.
Αυτή η αναφορά θα παρείχε περισσότερες πληροφορίες με
"Εμφάνιση πλεονάζουσα έξοδος κατά τη σύνταξη"
Επιλογή από το Αρχείο -> Προτιμήσεις.
Last edited by Fernando Garcia on Mon Feb 13, 2017 8:47 am, edited 1 time in total.
Reason: Pease use the tag [code][/code] to post codes.
Post Number:#4 Post Mon Feb 13, 2017 8:52 am
Copy the files .c for fonts from here: https://github.com/FernandoGarcia/Ferdu ... tecas/UTFT
Regarding this version of Ferduino you should ask for help here: https://github.com/Wolfire18/Ferduino_800x480res/issues
Post Number:#5 Post Mon Feb 13, 2017 10:20 am
Greece
thanks fernando i try to copy the files from libraries. load without errors but on display i see the message please insert a sd card.
i need sd card?
my card socket is on tft
i dont work with thernet shield or wifi etc
Post Number:#6 Post Mon Feb 13, 2017 10:37 am
i need sd card?
Obviously.
I'll close this topic because the initial question was answered.
