As I received my ethernet shield W5100,I tried to install the new version of Joyreef but I systematically received the same error during sketch verification
This report would have more information with
Code: Select all
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Mega 2560 or Mega ADK"
Webserver.ino: In function 'void processRequest()':
Webserver:11: error: 'class EthernetClient' has no member named 'getRemoteIP'
Webserver.ino: In function 'void requestAction(byte)':
Webserver:179: error: 'class DS1307' has no member named 'getTimeStamp'
Webserver.ino: In function 'void enviar_dados()':
Webserver:883: error: 'class DS1307' has no member named 'getTimeStamp'
Webserver:922: error: 'class DS1307' has no member named 'getTimeStamp'I have search in the forum but I can't find an answer.
I have uninstalled Arduino several times and upload the new Joyreef also several times, modified DS1307 library and changed ethernet library by the new one,tried differents IP Address but nothing to do, always the same problem.
Could you once more help me.
Thanks in advance
Best regards,
Jean-Yves
