Forum Hardware Main board Power supply voltage
Power supply voltage  [SOLVED]
Post Number:#1 Post Thu Oct 16, 2014 4:26 pm
with what power supply voltage, you can supply the FerduinoMega? with power connector.
Because with a 12v DC the regulator is too heat
Post Number:#2 Post Thu Oct 16, 2014 4:43 pm
Any voltage between 7 and 12 V.
If you have the board powered with 12V, this voltage will be available on connector DB25 and RJ45 on pins called V = VIN. So you can use this 12 V to supply the relay board and dosing pumps otherwise need of an external power supply.
You need check what is better add a small fan, use 2 power supplies or 1 of 12 V and an additional regulator.
The fan can be connected on VIN available on power header.
Post Number:#3 Post Thu Oct 16, 2014 4:48 pm
Hi
I understand that
Return to Main board
