Forum Software Joyreef app Webserver problem
Webserver problem
Here you can relate issues with joy-reef.com.
Moderator: Developers
Post Number:#1 Post Mon Jul 14, 2014 11:36 am
Hello again I'm having trouble with shild W5100'm trying to use the webserver version however is not working did all the settings to use the W5100 jumper pin 10 to 53 etc. ... just not with this jumper fixed ip have chosen, then changed the SelectSlave_ETH to pin 10 and changed the led that used pin 10 to pin 53 thereby set the ip I had pre configured (192.168.0.4) doing ping test in cmd this works ok but not the webserver still not works did the test as post citing enter a command in the browser (http://192.168.0.200:21/?cmd=your_usern ... in_base_64, 0, k) referring to the IP ferduino however it still fails the router where this connected system this with all ports 1-65535 to open this ip
Anyone have any idea what it might be? will my W5100 with this problem?
Post Number:#2 Post Mon Jul 14, 2014 1:56 pm
If you have a jumper between the pin 10 and 53 no need change the "SelectSlave_ETH" to 10.
Use:
SelectSlave_ETH = 53;
Also no need change the LED pin.
I never told to change this.
Look this topic: viewtopic.php?f=8&t=34
Post Number:#3 Post Mon Jul 14, 2014 6:56 pm
Use:
If I do not change from 53 to 10 (which I'm calling the select eth) he gets the ip 0.0.0.0, even taking the pin 10 and doing the jumper this problem happens, the only way that it takes the ip I configured is changing from 53 to 10
And for me byte ip[] = {192,168,0,177}; // Configure o IP conforme a sua rede local. not work i not understand problem... for me work IPAddress ip (192,168,0,4) can I set the ip in the code however answers the webserver does not work.
I believe that my problem is not with the network configuration or ip but something else I do not know what it is but I'll find out.
Post Number:#4 Post Mon Jul 14, 2014 10:20 pm
Post Number:#5 Post Tue Jul 15, 2014 8:07 am
correction:
after test variable type "byte" work fine, my problem "port" I can not use another port other than 80 with the other ports not working.
Testing yesterday directly by the local ip worked the answer came from ferduino left for this to change port 53 to 10 as I have said before now just need to figure out why it only works with port 80 just this port is blocked by many operators / providers in testing I use a Linksys WR54G modified to serve as a repeater signal from the router in my cell I use the DD-WRT V24 system's firewall is off and I am using DMZ to the ip configured on ferduino (192.168.0.4) moreover still did redirection doors like I said before all ports from 1 to 65535 are directed to the same ip ferduino this way the system reacts only configure port 80 believe this problem is caused by your mobile provider I'm using at the moment I can not test with other kind of internet signal also can not claim that it is operator problem that is just a guess using a web server (Tomcat 8.0) in notbook can deliver signal on any port alert by external ip can not understand what I'm trying to solve case someone have any idea what might be and help me solve'm grateful.
Post Number:#6 Post Tue Jul 15, 2014 11:17 am
What's the problem to use the port 80?
Post Number:#7 Post Tue Jul 15, 2014 11:50 am
Return to Joyreef app
