Forum Software Joyreef app Error of connection
Error of connection  [SOLVED]
Here you can relate issues with joy-reef.com.
Moderator: Developers
Post Number:#1 Post Tue May 20, 2014 1:00 pm
Germany
Hallo an alle .
Ich komme aus deutschland ( kann kein englisch)
ich hab ein problem , ich bekomme immer eine fehlermeldung
error connecting
bitte helf mir
Post Number:#2 Post Tue May 20, 2014 1:02 pm
Adrian, please use the google translator and edit your post.
If your problem isn't with password please open a new topic.
Hallo!
Adrian, nutzen Sie bitte dass Google-Übersetzer und bearbeiten Sie Ihre Post.
Wenn Ihr Problem ist nicht mit Passwort öffnen Sie bitte ein neues Thema.
Post Number:#3 Post Tue May 20, 2014 1:29 pm
Germany
Olá a todos.
Eu sou da Alemanha.
Fico sem conexão com o app de jo-Recife com a senha que eu também não klaar.
Você pode me ajudar?
Post Number:#4 Post Tue May 20, 2014 1:36 pm
Images: 1
Hi Adrian,
Are you sure you set the port in the right way?
Are you sure you made the configuration of your firewall to do port forwarding of the port to the right ip address of your LAN?
When it says "error connecting " it's not a password problem...
Post Number:#5 Post Tue May 20, 2014 1:38 pm
Germany
You can please me step for step explaining how to log on with joy-reef with a password using 6 characters.
and I can't get out there the other settings to the server.
-------------------------------- Last edited May 20th, 2014, 1:43 pm --------------------------------
think it really is, I can my ip from the arduino ping and the Horst address of my no-ip also does not go but unfortunately in the joy-reef app
Post Number:#6 Post Tue May 20, 2014 1:45 pm
Images: 1
1) log in joy-reef.com
2) In the upper right corner click on Ferduino password
3) set the ferduino password (only numbers, 6 digit) Es. 123456
4) open arduino ide, in the Ferduino tab search for
char *credencial = "teste:123456";
5) replace teste with your joy-reef username and 123456 with the ferduino password you set at point 3
6) log in joy-reef.com
7) In the upper right corner click on settings
8) set the right host address and the right port
9) Setup your modem / router to port-fordward the port you choose to the internal LAN address of your arduino
10) enjoy
Post Number:#7 Post Tue May 20, 2014 1:47 pm
Germany
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Dokumente und Einstellungen\Adrian>ping 192.168.2.117
Ping wird ausgeführt für 192.168.2.117 mit 32 Bytes Daten:
Antwort von 192.168.2.117: Bytes=32 Zeit<1ms TTL=128
Ping-Statistik für 192.168.2.117:
Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0 (0% Verlust),
Ca. Zeitangaben in Millisek.:
Minimum = 0ms, Maximum = 0ms, Mittelwert = 0ms
C:\Dokumente und Einstellungen\Adrian>ping adrianaquarium.no-ip.biz
Ping adrianaquarium.no-ip.biz [87.146.213.154] mit 32 Bytes Daten:
Antwort von 87.146.213.154: Bytes=32 Zeit<1ms TTL=64
Ping-Statistik für 87.146.213.154:
Antwort von 87.146.213.154: Bytes=32 Zeit=3ms TTL=64
Antwort von 87.146.213.154: Bytes=32 Zeit=1ms TTL=64
Minimum = 0ms, Maximum = 3ms, Mittelwert = 1ms
Post Number:#8 Post Tue May 20, 2014 2:03 pm
Images: 1
You have to forward the port 80 to your internal ip address 192.168.2.117.
To do this you have to enter your modem, usually at http://192.168.2.1, and set port forwarding under NAT, or FIREWALL settings.
What is the model of your modem?
Post Number:#9 Post Tue May 20, 2014 2:08 pm
Adrian, your posts were moved because your problem is different.
Post Number:#10 Post Tue May 20, 2014 3:47 pm
Germany
Hallo , Joy-reff App. Is ok .my Router is Wong ( Def.)
New Router ok.
Danke danke :ymhug:
Post Number:#11 Post Tue May 20, 2014 3:48 pm
Images: 1
Glad to hear :D
Post Number:#12 Post Tue May 20, 2014 5:08 pm
Very cool!
Return to Joyreef app
