Forum Members section LED light and others Cooling LED screen
Cooling LED screen  [SOLVED]
Post Number:#1 Post Tue Aug 25, 2015 11:11 am
Good Fernando , first thank you for your great work I really admire is like a person has bothered to share such an expensive work in all aspects ... I wanted to ask you a question because I 'm riding my ferduino and 'm riding circuit assembly according RECOMMEND :
because my fans are 12 V and doubts I have are ;
* I will put 3 , connect them in parallel with the other, or goes in the F2 ULN2003A ? ... And third in the F3 ventiador ?.
* and all pins are spliced ​​1 to 7 and pin 1 ULN2003A ? ... I do not understand to do where you put pin1 disable that I have to do ?
Good is that there are several questions and I would be very grateful to you for help .
Regards.
Post Number:#2 Post Tue Aug 25, 2015 11:27 am
Welcome Jose!
Use a pin to each fan.
Yes, all pins of control are in parallel.
The pin 1 is used to turn ON or OFF the fans. See the code here.
Post Number:#3 Post Tue Aug 25, 2015 3:21 pm
Fernado ... thank you very much for your quick response and dsiculpa my bad English.
F1 will do so because the fan 1
F2 2
F3 3
and the other part of the integrated 1 to 7 together and to pin 1 . ^:)^
Thanks again.
Post Number:#4 Post Wed Aug 26, 2015 4:53 pm
fernado good again , I forgot to comment you the question I asked how Ivan ...
I stay connected fans ask is done with PWM cable laying pin13 , thank you very much again.
Regards.
Post Number:#5 Post Wed Aug 26, 2015 6:21 pm
Yes, as you can see on schematic.
Post Number:#6 Post Thu Aug 27, 2015 2:15 am
Hello Fernando apology you ask again ... then connect my fans as they will have 3 12 v cables (red, black, yellow). Thank you
Post Number:#7 Post Thu Aug 27, 2015 2:25 am
Hello Fernando, as I connect my 3 fans you have. 3 red, black, yellow) cable ??
Thank you.
Post Number:#8 Post Thu Aug 27, 2015 10:36 am
Post Number:#9 Post Thu Aug 27, 2015 1:20 pm
