Forum Members section DIY Ferduino controller Step By Step for Dummies?
Post Number:#1 Post Sat Aug 09, 2014 12:00 am
Columbia
Hi all
My name is Carlos Llanos and reading I found portalpez.com domain automate an aquarium with arduino but that project (Excellent project) is obsolete and end of the post to post ferduino recommended. Now I have a question: is there some post such as the portalpez http://www.portalpez.com/1-vf7-vt51459. ... sc&start=0 in a step by step summary ?.
Excuse for my English, I used Google translate to for this.
Hola a todos
Mi nombre es Carlos Llanos y leyendo del dominio portalpez.com encontré como automatizar un acuario con arduino pero ese proyecto (Excelente proyecto) ha quedado obsoleto y al final del post recomendaban al post de ferduino. Ahora tengo una pregunta: ¿existe algun post tal como el del portalpez http://www.portalpez.com/1-vf7-vt51459. ... sc&start=0 en resumen un paso a paso?.
Gracias
Perdonen mi ingles, usé translate de Google para esto.
Post Number:#2 Post Sat Aug 09, 2014 11:49 am
Welcome Carlos!
You can find all circuits, part list and step by step to install the code on links below.
How to install Ferduino code
Part list
Circuits
Code for tests
If you have any question can post here.
Post Number:#3 Post Sat Aug 09, 2014 12:10 pm
Columbia
Welcome Carlos!
Part list
Circuits
Code for tests
Thanx Fernando
I will be reading this post, I hope come to good port.
I have a question: These components are used for freshwater aquariums ?, no plan to have some version of your hardware simpler ?, such as sensor ph only two circuits for temperature, etc.
Post Number:#4 Post Sat Aug 09, 2014 12:28 pm
This components can be used to freshwater or saltwater. The difference is that to freshwater you no need of circuits for ORP and EC.
I'll not make another version, this code can be used to any type of tank.
If you no need of two PH sensors only no connect the second circuit, it no will interfere on controller.
Here have a good example of controller for freshwater.
Post Number:#5 Post Sat Aug 09, 2014 1:42 pm
Columbia
Hi there
One question: If I'm just going to have LED lights, temperature control fans need all the elements?
Another question: In this image gallery/image.php?album_id=11&image_id=70, what is the function the R2 resistors and the GND-FONTE-E-ARDUINO?
Post Number:#6 Post Sat Aug 09, 2014 1:48 pm
No, you need:
Arduino mega 2560;
TFT touch 400 x 240;
TFT shield with RTC;
Temperature sensors (ds18b20);
Prototype shield or screw shield.
-------------------------------- Last edited Sat Aug 09, 2014 1:57 pm --------------------------------
If you not want buy a prototype shield or screw shield, connect the wires on this way:
Post Number:#7 Post Sat Aug 09, 2014 3:29 pm
Columbia
Hi
Post Number:#8 Post Sat Aug 09, 2014 3:47 pm
The R2 is a resistor pull-down, check it : http://en.wikipedia.org/wiki/Pull-up_resistor
"Fonte" in english is power supply, you need connect the negative (GND or ground) from power supply and Arduino on this circuit.
The positive goes directly to the LED.
Post Number:#9 Post Sat Aug 09, 2014 4:27 pm
Columbia
Image: http://ferduino.com/forum/gallery/image.php?album_id=11&image_id=70
hi Fer
Sorry to bother you, I'm a bit ignorant on this issue, I have a doubt resistance, for example R2, R4, one leg is not connected to anything, and the GND-Fonte-Arduino-E, also did not see anything connected if I do not understand. That's OK?
Post Number:#10 Post Sat Aug 09, 2014 4:49 pm
No problem.
Look this image.
All this area is a signal of ground, all points highlighted are connected to it.
Post Number:#11 Post Sat Aug 09, 2014 5:38 pm
Columbia
No problem.
Look this image.
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=111
Ooh, thanx. Again, searching parts for my project, you recommend me this ITDB02 ARDUINO MEGA SHIELD V1.1 KIT http://imall.iteadstudio.com/im120717001.htmlbut this shield ITDB02 ARDUINO MEGA SHIELD http://imall.iteadstudio.com/im120417024.html , Is this last component can run me? only thing is that this component don't have rtc, I believe it. or this http://www.ebay.com/itm/400652791828, which one I must to choice?
Post Number:#12 Post Sat Aug 09, 2014 5:59 pm
You can buy this TFT shield but, first see this topic to not buy a RTC wrong.
This prototype shield is different of this:
Post Number:#13 Post Tue Sep 16, 2014 7:56 am
Portugal
Post Number:#14 Post Tue Sep 16, 2014 10:11 am
Here you can find the pin numbers and function to each one.
Post Number:#15 Post Tue Sep 16, 2014 1:43 pm
Portugal
Post Number:#16 Post Mon Dec 08, 2014 9:49 am
Hummmmmm...
Ok, THX, i don’t understand much of electronics and connections but I WILL TRY, AND I WILL SUCCEED B-) :D
Gerardo how is going your project?
It would be interesting if you post here a step by step according to what you would like of have found on forum.
Post Number:#17 Post Sun Oct 18, 2015 1:29 am
so following Fernando's request I am going to start from scratch thread here, I will work on each component as I get time and post updates regularly. So far I have most of what I need and I think I will start by building the stack. I will post some pictures soon, I would like any others to add their experiences as well this help take some of the questions that Fernando gets all the time and make a little brake for him. Thank all and lets have some fun.
