Forum Members section DIY Ferduino controller PCF 8575
PCF 8575
Post Number:#1 Post Fri Jul 11, 2014 1:52 pm
Germany
Post Number:#2 Post Fri Jul 11, 2014 2:15 pm
The solution to the problem with the RTC is change the pins to 18 and 19.
The problem is that Henning's library not allow 2 devices on same pins.
Need of 2 pins exclusive to the RTC.
If you put 3V on PCF8575 the output voltage will be 3V probably.
3V can be insufficient to activate some relays.
