Forum Members section DIY Ferduino controller Pcf8575 problem
Pcf8575 problem  [SOLVED]
Post Number:#41 Post Sat Dec 21, 2019 5:52 pm
Images: 280
Solve rating: 220
I have merged the topics maybe will make more sense.
I the first part of the video the guy is using an active HIGH relay board (red) and this module doesn't works with this type of board as shown on video.
With active LOW boards (blue) the relay are triggered correctly and we can hear the typical "click" from relays.
Please do not PM me for support unless it is absolutely necessary.
I'll not write custom function to nobody unless you can pay for my job.
Post Number:#42 Post Mon Dec 23, 2019 1:08 pm
Images: 5
hi Fernando and Jose,
I tried to connect everything as in the video.
if I connect the pcf8575 directly to the low level relay everything works but if I connect the high level relay through the uln2803a it doesn't work.
I hope the video is clear enough and sorry for the mess of the wires!
I attach another video where everything works with the other model of pcf8575.
I hope I was helpful
regards
Post Number:#43 Post Mon Dec 23, 2019 1:21 pm
Images: 280
Solve rating: 220
Gio, HIGH level relay board won't work with ULN because the signal is 0V (GND).
I have explained it here a few times. Please check this topic: https://ferduino.com/forum/viewtopic.php?f=6&t=100
Post Number:#44 Post Mon Dec 23, 2019 3:15 pm
Topics: 14
Images: 28
Topics: 14
I got confused in the previous answer.
I confirm that if I do not use the uln2803 and connect as in the video the relays get excited and work.
If I pass them through the ULN2803 then it is when the relays are dimmed and not excited.
Post Number:#45 Post Mon Dec 23, 2019 5:22 pm
Images: 5
hi,
happens to me exact the same thing that happens to Jose
regards
Post Number:#46 Post Mon Dec 23, 2019 5:31 pm
Images: 280
Solve rating: 220
ULN can't be used with HIGH level trigger relay board.
But I don't think it's your case because your relay board is LOW level trigger as shown here.
Here you told me that the relays are activated when pins 1 to 16 are connected to GND so the relays are really LOW level trigger.
Maybe you are placing the ULN in wrong position.
Post Number:#47 Post Mon Dec 23, 2019 6:38 pm
Topics: 14
Images: 28
Topics: 14
I don't know if it can be seen correctly but the ULNs are positioned as shown in the photo (the notch of the integrated one on the left). it's not like that?
Last edited by Fernando Garcia on Mon Dec 23, 2019 6:44 pm, edited 1 time in total.
Reason: Please post images using the tags [img=left][/img]
Post Number:#48 Post Mon Dec 23, 2019 6:58 pm
Images: 280
Solve rating: 220
The headers on PCF module seems poorly soldered here:
Can you remove the ULN from socket and measure the voltage between pins 1-8 on socket and GND with PCF signal HIGH? It should be around 5 v.
After can you measure the voltage between 5 V and pins 11-18 on socket with PCF signal HIGH? It should be around 5 V too.
Post Number:#49 Post Tue Dec 24, 2019 5:06 am
Topics: 14
Images: 28
Topics: 14
If I try HIGH
for (int i = 0; i <15; i ++)
     PCF8575.digitalWrite (i, HIGH); // Tun on all pin
Between pins 1-8 and 5V measures 0 V
Between pin 9 (GND) and 5 V it measures 4.96 V
Between pins 11-18 and 5 V it measures 0 V
Between pin 10 (COM) GND measures 0 V
But if I try LOW
     PCF8575.digitalWrite (i, LOW); // Turn off all pin
Between pins 1-8 and 5 V measures 4.96 V
Between pins 11-18 and 5 V gives 0 V
Between pin 10 (COM) and GND gives 0 V
Post Number:#50 Post Tue Dec 24, 2019 10:31 am
Images: 280
Solve rating: 220
Two mistakes here.
I did not told to measure in this way. Basically you are measuring between 5 V and 5 V, it won't give any voltage obviously because there's no potential difference.
What I told was:
Between pins 1-8 and GND (pin 9) it should give around 5 V as I told before.
As I told here with ULN connected the voltage should be around 1.5 V.
Here my question is incomplete. I forgot to say to put the ULN back on socket before measure.
Without ULN the socket pin is connected only to DB25 and it will give 0~1 V only.
With ULN connected between pin 11-18 should give around 5 V as I told before.
But if I try LOW
This test is not needed and will make the things more complicated here.
Post Number:#51 Post Tue Dec 24, 2019 1:24 pm
Topics: 14
Images: 28
Topics: 14
Apologies for not understanding how to perform the tests.
With HIGH pins with both ULN and without it between 1-8 and GND (9) it measures 0 V
With HIGH pins with both ULN and without it between 11-18 and 5 V it measures 0 V
Post Number:#52 Post Tue Dec 24, 2019 2:10 pm
Images: 280
Solve rating: 220
Try measure the voltage directly over the IC (PCF8575) between P00 (pin 4) and GND if it has the same result the module is not working or Arduino is not communicating with PCF correctly.
If over the IC has voltage so the problem is in bad header soldering as pointed previously.
Post Number:#53 Post Tue Dec 24, 2019 4:08 pm
Images: 5
hi,
I did some tests. I hope it can be useful!
regards
Post Number:#54 Post Tue Dec 24, 2019 4:56 pm
Images: 280
Solve rating: 220
Gio, pictures and texts should be more useful.
This video has bad quality (480p) and it's very short. Moreover I don't know your PCB.
When the multimeter is showing negative voltage is because the polarity is inverted. You should swap probes positions.
BTW, making videos in landscape is always the best choice.
Off Topic
Gio, I see your pics about the problem with web interface. I have fixed this bug, please check it. Thanks for it!
Post Number:#55 Post Tue Dec 24, 2019 8:12 pm
Images: 5
Off topic!
Thank you Fernando.
I hadn't had time to write to you! Now everything is perfect!
Post Number:#56 Post Wed Dec 25, 2019 6:14 am
Topics: 14
Images: 28
Topics: 14
Merry Christmas !!!
My knowledge of electronics is very limited so I go blind and I can only move forward thanks to your help Fernando.
Performing measurements as indicated (from the PCF8575 pin to GND) the result is 0 V.
What I don't understand is that if I don't use the ULN modules it seems to work correctly.
Even if I bypass the ULN socket also works.
Post Number:#57 Post Wed Dec 25, 2019 2:28 pm
Images: 280
Solve rating: 220
Merry christmas for all!
For some reason this module is not working as OUTPUT just as INPUT.
You can notice that relay is just turned on when a LOW command is sent.
The solution could be bypass the ULN and change on code LOW to HIGH and HIGH to LOW.
But I'm not sure if PCF can manage the current of all relays.
Try this code bypassing the ULN and check the behaviour and serial monitor.
#include "mxUnifiedPCF8574.h"
mxUnifiedPCF8575 PCF8575 = mxUnifiedPCF8575(0x20); // Endereço em hexadecimal = 0x20
  while(!Serial)
  Serial.println("I'm alive!");
  PCF8575.begin();
  for(int i = 0; i < 16; i++)
    PCF8575.pinMode(i,OUTPUT);
   Serial.println("\n\nTuning OFF all relays");
    PCF8575.digitalWrite(i, HIGH); // Tun on all pins
    delay(200);
    Serial.print("pin ");
    Serial.print(i);
    Serial.print(": ");
    Serial.println(PCF8575.digitalRead(i) ? "HIGH" : "LOW");
  delay(5000);
  Serial.println("\n\nTuning ON all relays");
    PCF8575.digitalWrite(i, LOW); // Turn off all pins
    delay(200);
    Serial.print(i);
    Serial.print(": ");
  delay(5000);
Edit:
If the circuit is working as I told above to prevent damage PCF I think that ULN could be replaced by a PNP transistor array and TD62384AP seems suitable.
Last edited by Fernando Garcia on Wed Dec 25, 2019 3:05 pm, edited 1 time in total.
Reason: Fix info in edit.
Post Number:#58 Post Wed Dec 25, 2019 7:49 pm
Topics: 14
Images: 28
Topics: 14
It behaves as you say, following the output to the serial monitor the relays turn on in LOW and turn off in HIGH.
I had to compile the code with the PCF8575.h library since with the mxUnifiedPCF8574.h it gives me a compilation error (I have previously installed the library).
As seen in the video, the 16 relays light up.
To take advantage of the PCB that I have already manufactured, do you think the system will work by removing the ULN and bypassing the socket? (in addition to modifying in the code HIGH pot LOW and LOW by HIGH).
Is it possible to acquire somewhere the PCF module that behaves in reverse mode?.
Post Number:#59 Post Wed Dec 25, 2019 10:31 pm
Images: 280
Solve rating: 220
You should find a module with a PCF8575TS instead PCF8575C.
Ferduino Mega and blue module has TS type. Should have some difference betweem TS and C type.
If you can't find this type can buy only the IC and replace on red module.
Post Number:#60 Post Thu Dec 26, 2019 4:12 am
Topics: 14
Images: 28
Topics: 14
I do not find the PCF8575TS module mounted and the truth is that I am not able to replace the integrated module on the red module.
Is it possible to work simply by removing the ULN2803 and bypassing the sockets? Apparently it seems so, but I don't know if the use could cause problems.
Thank you and at least I know what the problem was.
PreviousNext
  • Similar Topics
    Replies
    Views
    Last post
