Forum Members section DIY Ferduino controller Touchscreen Problem ILI9481
Touchscreen Problem ILI9481  [SOLVED]
Post Number:#1 Post Sun Dec 23, 2018 11:36 am
Germany
I have a problem! I want to calibrate my touch screen with UTouch
so I have the correct coordinates for the Ferduino controller.
But it is harder than I thought! I've tested countless libraries now. My board has 480x320 picel labeled
ILI9481 a 3.5 "display
should work with TFT_HX8357 but nothing happens
I can not do it!
The only calibration that works is from MCUFRIEND_kbv
called Touchscreen Calibration Native
Test result:
cx=172 cy=926 cz=180 LEFT, TOP, Pressure
cx=168 cy=921 cz=201 LEFT, MIDH, Pressure
cx=150 cy=117 cz=592 LEFT, BOT, Pressure
cx=521 cy=940 cz=268 MIDW, TOP, Pressure
cx=152 cy=921 cz=201 MIDW, BOT, Pressure
cx=877 cy=937 cz=420 RT, TOP, Pressure
cx=880 cy=530 cz=535 RT, MIDH, Pressure
cx=884 cy=109 cz=661 RT, BOT, Pressure
MCUFRIEND_kbv ID=0x9486  320 x 480
const int XP=8,XM=A2,YP=A3,YM=9; //320x480 ID=0x9486
const int TS_LEFT=139,TS_RT=903,TS_TOP=946,TS_BOT=370;
PORTRAIT CALIBRATION     320 x 480
x = map(p.x, LEFT=139, RT=903, 0, 320)
y = map(p.y, TOP=946, BOT=370, 0, 480)
Touch Pin Wiring XP=8 XM=A2 YP=A3 YM=9
LANDSCAPE CALIBRATION    480 x 320
x = map(p.y, LEFT=946, RT=370, 0, 480)
y = map(p.x, TOP=903, BOT=139, 0, 320)
The TFT display is plugged directly onto my Arduino Mega
on the pins
A0-A4 GND- 5V- 3.3V reset
PWM 2-PWM12
Properties: //what i've buy
This TFT-LCD screen module with LCD break, SD card and Flash design. So it's a powerful extension module for your project.
Dimension: 3.5 inches
Controller: ILI9481 or ILI9488 driver (default random) //only ILI9481 works but not in UTOUCH
Resolution: 480x320
Data bits: 8 - 16
Interface pin number: 37 pin
Distance: 1 mm
This pin arrangement does not work!
because are not the right one
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield            : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board                   : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT    myGLCD(ILI9481,38,39,40,41); //3.5" TFTLCD for arduino 2560 from mcufriend.com
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield            : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield            :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due       :  6, 5, 4, 3, 2
// Teensy 3.x TFT Test Board                   : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
UTouch  myTouch( 6, 5, 4, 3, 2);
In The Touchscreen Calibration Native is only
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
In many Sketches the Pins are correct but nothing happens
display stays white
#define LCD_RST A4
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_D0 8
#define LCD_D1 9
#define LCD_D2 2
#define LCD_D3 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
I hope somebody can help me to integrate my display.
I still have a 3.2 "display but I have not worked on it yet.
I would like to first get the 3.5 "display to run
Last edited by Fernando Garcia on Mon Sep 23, 2019 3:04 pm, edited 2 times in total.
206 gallon tank, 42 gallon technic sump, system triton core 7, 8 dosing Pumps, AM Aquarius, AM Reef LED, AM Ocean LED at TC420, AM Temp controller, Skimmer Bubble Magus Curve M7, 3 Tunze flow pumps at Tunze Multi Controller 7096, AM refill system pro
Post Number:#2 Post Sun Dec 23, 2018 1:33 pm
Sorry, this model is not compatible with Ferduino and this model is not in my part list. So I can't help you.
Post Number:#3 Post Mon Dec 24, 2018 11:48 pm
Germany
this is my Touchscreen
Post Number:#4 Post Wed Dec 26, 2018 3:28 pm
Germany
Can you told me some touchscreen 3,5“ or i know must fit in code 7,0“ that is compatible with uTouch and UTFT that I can buy to run Ferduino Aquarium Controller
Post Number:#5 Post Wed Dec 26, 2018 10:44 pm
Germany
I've an Pin settings for my ILI9486 3,5" Ilitek Touchscreen in UTouch Calibration
to fit for Ferduino Code
UTFT    myGLCD(ILI9486,A2,A1,A3,A4); //3.5" TFTLCD for arduino 2560 from mcufriend.com
UTouch  myTouch(31,32,33,34,35);
Pin Settings put to Analog A0-A4
LCD_RS = A2
LCD_WR = A1
LCD_CS = A3
LCD_RST = A4
LCD_RD = A0
Pin Settings put to Digital D30-D37
LCD_D2 = D35
LCD_D3 = D34
LCD_D4 = D33
LCD_D5 = D32
LCD_D6 = D31
LCD_D7 = D30
LCD_D0 = D37
LCD_D1 = D36
5V = 5V
3,3V = 3,3V
GND = GND
When I upload Utouch Calibration display stay white nothing happens
what is my mistake what is the correct pin setting for my Display
I use many different Settings for pins but still white no calibration
Post Number:#6 Post Thu Dec 27, 2018 4:16 pm
As I told this TFT is not in my part list and is not compatible with my code. There's no support for this hardware here.
Also you can buy a TFT 5" or 7" with resolution 800 x 480 and controller SSD1963 but you should edit the code by yourself.
