Forum Members section DIY Ferduino controller Dosing And Wavemaker Pause for a while
Dosing And Wavemaker Pause for a while  [SOLVED]
Post Number:#1 Post Sat Nov 24, 2018 6:40 am
there is a way for the wavemaker to run smoothly, not to paused every 5 seconds. is it because Arduino cannot be multi-tasking. And dosing pump when it works all features stop for a moment. :-?
Thanks.
Post Number:#2 Post Sat Nov 24, 2018 10:26 am
Sorry, I don't understand fine.
What it should make every 5 seconds while dosing?
Post Number:#3 Post Sat Dec 01, 2018 6:51 pm
No more info?
Post Number:#4 Post Wed Dec 12, 2018 9:26 am
sorry if my speak is not good, I mean why wavemaker doesn't it work smoothly, stuttered every 5 seconds. :)
and I need you to check the wavemaker function, if in night mode and condition in mode reef crest there is a slight problem.
thank you.
Post Number:#5 Post Wed Dec 12, 2018 7:22 pm
Friend, I have explained it for you here.
Every 5 - 6 seconds Arduino is checking others functions.
Regarding dosage, the way to make it very accurated is using delay and during this time Arduino won't make anything else. You can try using millis but the code can hang in some part and a big amount will be dosed in your tank.
Here you can try make something using while replacing this delay to make something during dosage.
Example:
unsigned long millis_dosage = millis();
while((millis() - millis_dosage) < tempo_dosagem)
  digitalWrite(dosadora[i], HIGH);
  do_something_else();
