Forum Members section DIY Ferduino controller Sync failed ESP8266 MOD
Sync failed ESP8266 MOD  [SOLVED]
Post Number:#1 Post Mon Jul 23, 2018 9:10 pm
Good night ,
My name is Javier Rementeria,
I have arduino connected with ethernet shield and working properly but I want to change it by module ESP8266 MOD.
I have loaded the firmware according to the video tutorial (attached photos 2,3 and 4 ), I think correctly.
When i connect the module to the IDE and go to the serial monitor, the attached result appears (Photo 1).
My problem is that when I connect it to the Level converter MH module and to arduino and load the mqtt test code, it gives me an error (sync failed).
I changed the apikey that I had running with the ethernet shield.
Do you know what can be wrong?
Foto 1
Fotos 2,3 y 4
Thanks and best regards
Last edited by Fernando Garcia on Mon Jul 23, 2018 9:20 pm, edited 2 times in total.
Reason: Please post images correctly using tags [img=left][/img]. Don't use all letter in uppercase unless it's an abbreviation.
Post Number:#2 Post Mon Jul 23, 2018 9:24 pm
Welcome Javier!
In latest version of Ferduino and test code the baud rate is 9600 as you can see here:
https://github.com/FernandoGarcia/Ferdu ... t.ino#L118
https://github.com/FernandoGarcia/Ferdu ... p.ino#L162
Change the value in uC console in ESP-link interface.
All other settings seems right.
Post Number:#3 Post Tue Jul 24, 2018 8:06 pm
Hi Fernando ,
Thanks for the reply,
I changed the value in uC console in ESP-link interface to 9600 but it still gives sync failed when a tried with de example.
Attached photos
Do i have to turn off UART debug log
in ESP-link interface too?
Do i have to replace SoftwareSerial library?
I have tried everything but still giving error. Sorry but I dont know what to do.
After change to 9600, the serial monitor show my sync failed again and i´d tried the other option but nothing changed.
Thanks for the help
Last edited by Fernando Garcia on Tue Jul 24, 2018 8:54 pm, edited 1 time in total.
Reason: Please post images correctly using tags [img=left]URL[/img].
Post Number:#4 Post Tue Jul 24, 2018 8:56 pm
All settings are ok it should be a hardware problem.
Check the circuit.
Post Number:#5 Post Wed Jul 25, 2018 6:56 pm
Indeed Fernando,
I have changed the voltage reduction module and it works.
Thanks for everything again
