Forum Members section DIY Ferduino controller Problem with TFT
Problem with TFT
Post Number:#1 Post Mon Jan 29, 2018 1:55 pm
Good afternoon.
I am visiting this post again to show that I bought the TFT indicated and it works with the code downloaded from the site directly. There is only one small flaw left, in the last line I show in the following image.
Is there a similar problem report?
One more doubt. Has anyone ever seen an assembly with flat cable to leave the TFT away from the board?
I'm noticing a bad connection between some components. Is it possible to send for maintenance?
I'd like to plan on acquiring other sensors as well.
Sidney
Last edited by Fernando Garcia on Mon Jan 29, 2018 8:54 pm, edited 1 time in total.
Reason: Please use tags [img=left][/img] to post images.
Post Number:#2 Post Mon Jan 29, 2018 9:07 pm
Strange chars in last line is related with problem with RTC. Are you using right configuration for jumpers and code? The battery is good?
You can buy a flat cable like this: https://www.ebay.com/itm/222550962390
Can you show me the problems?
