Forum Members section DIY Ferduino controller Extension wire TFT shield to screen
Extension wire TFT shield to screen  [SOLVED]
Post Number:#1 Post Sat Jul 08, 2017 7:07 am
Good morning and sorry for this silly question. I tried to find a wire to be able to separate the TFT shield from the screen but I only find IDE 40 pin cables and you have to modify one of the ends as it is not directly useful.
Are there wires already made? Or should I manually modify a standard IDE wire
Thank you very much
PS: searching the forum I have not found an answer either. And apologies for my bad English
Post Number:#2 Post Sat Jul 08, 2017 9:36 am
You are using wrong words :D
Try this:
search.php?keywords=flat+cable&terms=all&author=&sv=0&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
On Ebay search for "40 Pin Male to Female IDE Flat Ribbon Cable".
Here a result: http://www.ebay.com/itm/172768223884
Post Number:#3 Post Sat Jul 08, 2017 1:20 pm
I'm sorry to explain so badly, if I found IDE cable but what happens is what I try to show in the following scheme.
I hope you understand the drawing. Thank you
Post Number:#4 Post Sat Jul 08, 2017 1:45 pm
Crossing the wires TFT won't work.
It should match 1 to 1, 2 to 2 and so on.
Here an example with flat cable connected:
Post Number:#5 Post Sat Jul 08, 2017 10:03 pm
In my case what happens with the two IDE cables I've tried is the following:
For example, pin 40 is marked with the red arrows and for it to work I think the continuity should be with the green arrow.
Regards,
Post Number:#6 Post Sun Jul 09, 2017 4:23 am
I think the solution would be to use a cable like the link (Post Number: #5) but shorter.
http://ferduino.com/forum/viewtopic.php?f=24&t=354&p=2774&hilit=flat+cable#p2774
I wanted to know if they exist commercially or should I manufacture it myself. Thank you
Post Number:#7 Post Sun Jul 09, 2017 8:14 am
Your cable seems female to female but should be female to male.
