Forum Members section DIY Ferduino controller TFT not work
TFT not work  [SOLVED]
Post Number:#1 Post Sun Apr 10, 2016 7:29 pm
hi Fernando
I installed Arduino With webcontrol and charge me perfectly but the LCD screen goes blank, I changed to uTouch myTouch (6,5,4,3,2); and then to uTouch myTouch (7, 6, 5, 4, 3); and the image still does not appear lcd also clear the line #define USE_TFT and IDE does not work and I have loaded with 1.6.7 and nothing
any idea how to make it work?
I had installed the IDE 1.0.5r2 and worked perfectly.
With Ferduino installing contro web beta, the LCD is blank aqueda
Post Number:#2 Post Mon Apr 11, 2016 10:35 am
Only comment this line if you haven't a PCF8575:
#define USE_PCF8575 // Descomente essa linha para usar um PCF8575
Don't change this line:
#define USE_TFT
Post Number:#3 Post Mon Apr 11, 2016 8:58 pm
ok thanks fernando has been fixed
now comes the cd but I get message insert sd card have bridged r4 p53 but still leaving the message insert sd card,
the sd card is the one behind the LCD or otherwise need to add another reader sd to arduino? I'm trying to follow in the footsteps of Re: Ethernet W5100 and do not get it
my W5100 is this Image
roter need another reader sd?
that steps must follow
Thanks again
Post Number:#4 Post Mon Apr 11, 2016 10:49 pm
The initial problem on this topic was solved so, this topic will be closed.
To others problems create a new topic but first SEARCH on forum.
There answers for this problem with ethernet module and SD card like this:
viewtopic.php?f=8&t=329
viewtopic.php?f=8&t=322&p=2527
