Forum Members section DIY Ferduino controller TFT 800 X 600 - 7"
TFT 800 X 600 - 7"  [SOLVED]
Post Number:#21 Post Thu Nov 05, 2015 10:45 pm
Welcome Bruce!
You are talking about which board?
Post Number:#22 Post Wed Nov 11, 2015 10:42 pm
Images: 38
Hi
I already did all of the sequences which you said to follow in your forum. I am using Arduino Beta 7 from Willie and yet I have problems with of the verification from program when I do it. Then I need your help however I searched all in your topic in the forum but I had not results.
The picture below shows the wrongs that the program IDE 1.0.5 come up at screen.
best Regards,
Post Number:#23 Post Thu Nov 12, 2015 9:35 am
1- Use libraries downloaded with Willie's code!
2 - Change the RTC librarie as explanained here: viewtopic.php?f=8&t=34
Post Number:#24 Post Fri Nov 13, 2015 12:55 pm
Images: 38
Hi Fernando
I done two step, but the problem was not solved.
Best Regards
Post Number:#25 Post Fri Nov 13, 2015 1:31 pm
For this reason I don't want give support to others versions of Ferduino.
All informations needed to install official version of Ferduino are here:
video/viewvideo.php?id=3
If you can't understand the step by step and use for this version I'm sorry.
Post Number:#26 Post Mon Nov 16, 2015 5:16 pm
Images: 38
Fernando
Thanks for all your help.
Are possible to use all the program without webserver?
What I need disable?
Best Regards
Post Number:#27 Post Mon Nov 16, 2015 7:01 pm
Yes, only change this variable to false:
https://github.com/FernandoGarcia/Fedui ... a.ino#L426
as you can see on comment in good portuguese.
Post Number:#28 Post Tue Nov 17, 2015 9:19 pm
Images: 38
Fernando
Sorry my insistence but I tried all step you recommended and I didn't have success.
Now I disabled the ethernet and continues with same problems in bellow
Could you help me more?
Best Regards
Post Number:#29 Post Tue Nov 17, 2015 9:41 pm
Willie didn't update in ethernet library. On this case you can use this: https://github.com/FernandoGarcia/Fedui ... s/Ethernet
Post Number:#30 Post Sat Dec 05, 2015 8:09 am
I have fixed this issues via Team Viewer.
Willie's code have many problems with outdated libraries and codes incomplete.
I will not give anymore support to non official versions.
