Forum Members section DIY Ferduino controller Ignition of relays
Ignition of relays  [SOLVED]
Post Number:#1 Post Mon Oct 05, 2015 6:04 pm
Images: 4
Hello Fernando. I have a relay module and the problem is that the code that i have ferduino when it sends the signal to the relay is off, that is to say that work the other way around, how can I change it?
Post Number:#2 Post Mon Oct 05, 2015 6:20 pm
Are you talking that relays are OFF when should be ON and vice versa?
viewtopic.php?p=864#p864
Post Number:#3 Post Mon Oct 05, 2015 6:39 pm
Images: 4
Yes, that I would like to say i. That works the other way around
Post Number:#4 Post Sun Oct 11, 2015 3:47 pm
Images: 4
Hello Fernando. I already tried the relays with the ULN2803 and it seems that if it works. But now, the clock does not mark well it is as if voltage is missing, i come out as you can see in the photo. I connected and mark well the hour but after half a minute is as well. I have a doubt, have if you are going to be why do in the ULN2803 that I put it in the post connects the gnd capita there not to put the 5v to pin 10 of the ULN2803 is free?
Post Number:#5 Post Sun Oct 11, 2015 4:29 pm
Yes, the pin 10 isn't connected as you can see on schematic.
You have other topic to talk about power supply.
viewtopic.php?f=24&t=297
For now the initial question is solved.
