Forum Members section DIY Ferduino controller Temperature probes
Temperature probes  [SOLVED]
Post Number:#21 Post Sun Sep 20, 2015 5:03 pm
Images: 4
Hello, I just checked and this is the result: 0 probes found.
Post Number:#22 Post Sun Sep 20, 2015 5:33 pm
You did upload of images on forum, now only copy the link in "Image-URL:" and post on this way.
 [img=left]http://www.ferduino.com/forum/gallery/image.php?album_id=42&image_id=373[/img]
Try the example using another pin, maybe the pin 49 is with problem.
Change this line:
#define ONE_WIRE_BUS 49
Post Number:#23 Post Mon Sep 21, 2015 10:55 am
Images: 4
Hello, I still have not resolved the problem. I have been looking for the line that your telling me that change by the pin 49 if it is damaged, but I don't know where to go for it. Because the code Ferduino (where is the numbering of pins), does not appear that line.
Post Number:#24 Post Mon Sep 21, 2015 11:00 am
I'm talking about the example available here: viewtopic.php?f=8&t=42
Post Number:#25 Post Tue Sep 22, 2015 4:43 pm
Images: 4
Dallas Temperature IC Control Library Demo
Hello Fernando yesterday evening I looked at the example that your thou badest me. Also I change the number of the pin, but when i try i always leaves "Requesting temperatures ... DONE" all the while the same words. It is as if you did not find the probes. Anyway I bought some probes with cables, to check if the problem is in the probes. So I'm waiting for their probes.
This is the example:
Locating devices...Found 0 devices.
Parasite power is: OFF
Requesting temperatures...DONE
Post Number:#26 Post Sun Oct 04, 2015 5:54 am
Images: 4
Hello Fernando. This is fixed now, at the end were the DS18B20, i put a cable and now if it works. Thanks for the help
