Forum Members section DIY Ferduino controller Relays
Relays  [SOLVED]
Post Number:#1 Post Mon Sep 07, 2015 2:39 pm
Images: 4
Hello Fernando.
Back again to the project and now comes the problem I relays .
Where they connect pin why put in your own pin code 80,81,82,83,84,85 , and the mega pin plate these do not exist only until 53 I think.
I just want to connect 5 relays and do not like , and read to change the pin to pin unused but as I do that ???? .
Not if I have to get into the code and change the pin number to one that no longer used and whether easy or not so .....
I have not moved anything of yours and code for marine why I have little idea.
A greeting
Post Number:#2 Post Mon Sep 07, 2015 2:58 pm
The question is simple.
If you haven't dosing pumps by example can change this code:
const byte dosadora1 = 63;
const byte dosadora2 = 64;
const byte dosadora3 = 65;
const byte dosadora4 = 66;
const byte dosadora5 = 67;
const byte temporizador1 = 80;
const byte temporizador2 = 81;
const byte temporizador3 = 82;
const byte temporizador4 = 83;
const byte temporizador5 = 84;
const byte dosadora1 = 80;
const byte dosadora2 = 81;
const byte dosadora3 = 82;
const byte dosadora4 = 83;
const byte dosadora5 = 84;
const byte temporizador1 = 63; // A9
const byte temporizador2 = 64; // A10
const byte temporizador3 = 65; // A11
const byte temporizador4 = 66; // A12
const byte temporizador5 = 67; // A13
Post Number:#3 Post Mon Sep 07, 2015 3:48 pm
Images: 4
Pino 5 também é o chip select do cartãoSD.
const byte ledPinUV = 8;         // Pino que liga os leds violeta
const byte ledPinBlue = 9;       // Pino que liga os leds azuis
const byte ledPinWhite = 10;     // Pino que liga os leds brancos
const byte ledPinRoyBlue = 11;   // Pino que liga os leds "royal blue"
const byte ledPinRed = 12;       // Pino que liga os leds vermelho
const byte fanPin = 13;          // Pino que controla a velocidade das ventoinhas do dissipador
// Pinos 14 e 15 reservados para a porta serial 3 que se comunica com os "Stamps"
const byte multiplexadorS0Pin = 16; // Pino S0 de controle dos stamps
const byte multiplexadorS1Pin = 17; // Pino S1 de controle dos stamps
// Pinos 18 e 19 reservados para o RTC.
// Pinos 20 e 21 reservados para comunicação I2C do PCF8575.
// Pinos 22 à 41 reservados para o LCD.
const byte aquecedorPin = 42;   // Pino que liga o aquecedor
const byte chillerPin = 43;     // Pino que liga o chiller
const byte ledPinMoon = 44;     // Pino que liga os leds da luz noturna
const byte wavemaker1 = 45;     // Pino que controla o wavemaker 1
const byte wavemaker2 = 46;     // Pino que controla o wavemaker 2
const byte ozonizadorPin = 47;  // Pino que liga o ozonizador
const byte reatorPin = 48;      // Pino que liga o CO2 do reator.
const byte sensoresPin = 49;    // Pino que lê os sensores de temperatura
// Pinos 50, 51 e 52 reservados para comunicação SPI
// Pino 53 reservado para "select slave do ethernet shield.
const int sensor1 = A0;        // Pino analógico que verifica se há tensão na bóia da quarentena.
const int sensor2 = A1;        // Pino analógico que verifica se há tensão na bóia inferior do sump.
const int sensor3 = A2;        // Pino analógico que verifica se há tensão na bóia superior do sump.
const int sensor4 = A3;        // Pino analógico que verifica se há tensão na bóia inferior do reservatório.
const int sensor5 = A4;        // Pino analógico que verifica o nível do reef.
const int sensor6 = A5;        // Pino analógico que verifica o nível do fish only.
const int bomba1Pin = A6;      // Bomba que tira água da quarentena.
const int bomba2Pin = A7;      // Bomba que tira água do sump.
const int bomba3Pin = A8;      // Bomba que coloca água no sump.
const int dosadora1 = A9;      // Bomba dosadora 1
const int dosadora2 = A10;     // Bomba dosadora 2
const int dosadora3 = A11;     // Bomba dosadora 3
const int dosadora4 = A12;     // Bomba dosadora 4
const int dosadora5 = A13;     // Bomba dosadora 5
const int dosadora6 = A14;     // Bomba dosadora 6
// Pino A15 reservado para SS do RFM12B
///**************** PCF8575TS **********************************
const byte temporizador1 = 80;       // P0       // Pino que liga o timer 1.
const byte temporizador2 = 81;       // P1       // Pino que liga o timer 2.
const byte temporizador3 = 82;       // P2       // Pino que liga o timer 3.
const byte temporizador4 = 83;       // P3       // Pino que liga o timer 4.
const byte temporizador5 = 84;       // P4       // Pino que liga o timer 5.
const byte solenoide1Pin = 85;       // P5       // Liga a reposicao de água doce.
Hi fernando just I look at the code and I find as I put in the message.
In the code I download is so .
Download the Spanish version ferduino without webserver .
Last edited by Fernando Garcia on Mon Sep 07, 2015 4:40 pm, edited 1 time in total.
Post Number:#4 Post Mon Sep 07, 2015 5:43 pm
Images: 4
// Pino A15 reservado párrafo SS hacer RFM12B
/// **************** **************** PCF8575TS ******************
byte temporizador1 const = 80; // // P0 Pino Que liga o temporizador 1.
byte temporizador2 const = 81; // // P1 Pino Que liga o temporizador 2.
byte temporizador3 const = 82; // P2 // Pino Que liga o temporizador 3.
byte temporizador4 const = 83; // // P3 Pino Que liga o temporizador 4.
byte temporizador5 const = 84; // P4 // Pino Que liga o temporizador 5.
byte solenoide1Pin const = 85; // // P5
this is what I have to change ?
Last edited by Fernando Garcia on Mon Sep 07, 2015 5:55 pm, edited 1 time in total.
Post Number:#5 Post Mon Sep 07, 2015 5:54 pm
For Arduino IDE it's the same thing:
63 = A9
64 = A10
65 = A11
66 = A12
67 = A13
So no matter if you will use A9 or 63 on code.
Post Number:#6 Post Tue Sep 08, 2015 6:48 pm
Images: 4
Hello Fernando .
Already this resolved as you said .
A greeting.
