Forum Members section DIY Ferduino controller Problem with Temperature Sensors
Post Number:#1 Post Fri Aug 14, 2015 8:29 am
First of all, hello to everybody in special to Fernando. Congratulations and thanks for your hard work.
The problem I have is that during light (sunrise starts at 8:15 and night starts at 21:45) time (when lights are off they work properly), temperature sensors decrease (or in any moment do not give signal) somo degrees.
Attached are some charts to show that.
https://www.dropbox.com/sh/u5t726uqu9io ... dBxZa?dl=0
This other are from when I only have 2 sensor connected:
It give me some problems because fans stops when they must run, heaters starts when they do not have...
If, for example,When I see a uncommon temperature (from LCD or via web), if I go to temperature sensors, they continue with wrong value but if I serch for them, the correct value appairs again.
Could you help me??
Last edited by Fernando Garcia on Fri Aug 14, 2015 5:33 pm, edited 1 time in total.
Reason: Please use tags [img=left]URL[/img] to post images.
Post Number:#2 Post Fri Aug 14, 2015 5:42 pm
Welcome Diego!
Seems electric noise.
Which circuit are you using for fans and LEDs?
Try connect the fans in a power supply individually without speed control to see if it works better.
