Forum Members section DIY Ferduino controller Problem with ethernet shield
Post Number:#1 Post Tue May 26, 2015 3:51 pm
hello
I have a problem with the card eternet. It loses connection data both incoming and outgoing. unplugging the connector lan everything returns to work properly for some hours. Suggested some ??
danilo
Post Number:#2 Post Tue May 26, 2015 4:27 pm
Are you using latest version of Ferduino with web control?
Post Number:#3 Post Tue May 26, 2015 4:30 pm
Post Number:#4 Post Tue May 26, 2015 6:21 pm
You can use a watchdog to restart the controller automatically when the communication stops.
Fisrt you need check if the bootloader installed on your Arduino is ready for it.
Connect a push button on pin A3 and test this code:
[codebender]https://codebender.cc/embed/sketch:80258[/codebender]
Open the serial monitor to see the result.
Post Number:#5 Post Wed May 27, 2015 9:38 am
Post Number:#6 Post Wed May 27, 2015 10:23 am
Use only english please.
The Google can help you sometimes.
Here an example:
Post Number:#7 Post Wed May 27, 2015 2:36 pm
