Forum Members section DIY Ferduino controller Help in question, timer and relay.
Help in question, timer and relay.  [SOLVED]
Post Number:#1 Post Tue Apr 14, 2015 5:35 pm
I went back to the project and I am with a doubt.
I will use two timers and two relay (chiller and heater), the timer I switched the pin "temporizador1" to 47 and "temporizador2" for 48 who are orinalmente the pin ozonizadorPin and reatorPin that were disabled in the code.
had already spoken to Fernando and he said he could.
my doubt is whether these PINs will straight to relay or have to have some CI between the Arduino and the relay as unl2003?
Post Number:#2 Post Tue Apr 14, 2015 5:59 pm
If you have a relay board type active low only change on code LOW to HIGH and HIGH to LOW or use an ULN to convert the signal.
Otherwise connect directly.
It has been explained many times here.
