Forum Members section DIY Ferduino controller W5100 Ethernet
W5100 Ethernet
Post Number:#1 Post Fri Feb 13, 2015 9:02 am
hello Fernando
  I am trying to connect the W5100 specifically this, I think that the connections are well put them on pins 50,51,52,53
I think even here well but have the problems siguieltes
not if I'm getting data ip, mac, subnet ... etc well and which parts should be added
besides that I am following the tutorial how to install Ferduino With control'¨ web but I can not
when you compile with Arduino gives me error invalid application of sized to incomplete type uint8_t
Post Number:#2 Post Fri Feb 13, 2015 3:20 pm
that's not what I have to put in the ip, if it must be the ruter or computer, Mac also not whether to put the computer or W5100'm a little busy with that and on the monitor I get error array, using port 9600 baud
Baud is there to change? I think it's configuration problem that does not work for me. X( X( X(
thanks in advance
Post Number:#3 Post Tue Feb 17, 2015 9:54 am
Hi Fernando'm following your tutorials to put ethernet but I am not able to make it work got me I have the connections as follows:
vcc gnd,
miso ... 50
mosi .... 51
rst ........ 53
sck ...... 52
continued after the settings ferduino
How to install Ferduino with web monitoring
step by step
up to
To check if your home is right configuration, open the serial monitor the baud to 38400 in September.
your tutorial but in the serial monitor gives me error I have my doubts on how to get the IP in this part
mac byte [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // This MAC deve be unique Local na sua rede.
ip byte [] = {192, 168, 0, 177}; // Configure or IP under Local sua rede.
Dnsserver IPAddress (8, 8, 8, 8); // Configure or IP under Local sua rede. This é or do Google DNS, geralmente não é necessário move.
IPAddress gateway (192, 168, 0, 1); // Configure or "Gateway" under Local sua rede.
IPAddress subnet (255, 255, 255, 0); // Set to mask sua rede under Local rede.
EthernetServer server (5000); // Put here or number gives no seu Roteador holder configured to redirecionamento.
                                                     // O da porta number deverá be MANDATORILY um destes 80, 5000, 6000, 7000, 8000, 8080 ou 9000.
not if the mac gotta leave that or have to put another and the mo IP I have very clear how to put
Fernando have if I made a hand
  Thanks in advance
