Forum Members section DIY Ferduino controller Using W5100 ethernet shield via ISCP.
Using W5100 ethernet shield via ISCP.  [SOLVED]
Post Number:#1 Post Fri Oct 17, 2014 12:35 am
I think I have established, that if I use the W5100, then I need to connect VCC, GND, and ICSP pins. Then I use the SPI.h and Ethernet.h libraries.
I can only get these ethernet shields.
Network Ethernet Lan Shield Module Board W5100
Does anybody know if this is correct for these shields, it is not acceptable to fit this shield to the Mega.
I would like to wire up remotely, do I just wire the ICSP header for ethernet?
If this is correct, then what about SD, is this also on SPI, or does it use other pins?
Any help would be great. Thanks.
Jamie.
Post Number:#2 Post Fri Oct 17, 2014 8:40 am
This shield is compatible.
The SPI interface can be shared with many devices.
Check this topic.
Please before of create a topic search a bit, all this informations are on forum.
http://ferduino.com/forum/viewtopic.php?p=288#p288
Post Number:#3 Post Fri Oct 17, 2014 7:46 pm
Thank you. I have searched but search function is not returning very good results. It is best for me to search topic on Google and suffix with ferduino.com.
Also information is quite conflicting. As many description of the ethernet module on other sites uses various pin arrangements.
I just didn't wish to buy numerous items and get wrong.
Regards.
Post Number:#4 Post Fri Oct 17, 2014 8:02 pm
You can connect the ICSP headers using a cable like this:
And a wire between pin 10 (shield) and 53 (Arduino)
