Forum Members section DIY Ferduino controller PCF 8575C Problem
PCF 8575C Problem  [SOLVED]
Post Number:#1 Post Wed Jun 13, 2018 6:07 am
Germany
Hello,
today I tried to connect the PCF8575. The problem is that the HIGH level on the output is just about 1.6V instead of the expected 5V.
A0,A1,A2 is connected to ground. R1-R3 are 10k resistors.
Does someone know what's the issue?
Post Number:#2 Post Wed Jun 13, 2018 10:27 am
The voltage is around 1.6 V on PCF pin when there an ULN connected for this.
Remember that the signal is LOW (GND) in ULN output pins.
Post Number:#3 Post Thu Jun 14, 2018 2:29 am
Germany
Okay great. I thought that the HIGH level is 5V
Yes I know it's an NPN darlington transistor
Thank you :D
Post Number:#4 Post Thu Jun 14, 2018 5:05 am
Germany
The transistor doesn't open completly when PCF is connected. So i measured the PCF output pins with a oscilloscope and found out that it isn't 1,6V, it just have 5V peaks.
I measured P5-P9 why aren't they constant on HIGH? The timer is turned ON in display
regards Yannick
Post Number:#5 Post Thu Jun 14, 2018 11:10 am
I haven't an oscilloscope.
I just can say that the voltage in PCF pin is 1.6 V with ULN connected and 5V disconnected.
Which type of device you are trying to control?
Post Number:#6 Post Fri Jun 15, 2018 9:04 am
Germany
Okay I thought someone knows why the signal look so wierd like this . I will try to use an other IC at monday
Have a nice weekend and thanks for quick response :)
