Forum Members section DIY Ferduino controller Relay Funduino
Relay Funduino  [SOLVED]
Post Number:#1 Post Fri Mar 25, 2016 2:36 pm
Hi fernando while I could not connect've been away and now and resumed ferduino, first of all thank all the efforts you make to carry out all the projects of others,
I would like to know how to place or if you have schematic assembly relay for connection with ferduino since I do not dipongo plate ferduino and how to modify IDE since I'm a little rusty, and looking in the chat but can not find the solution for to connect the relays and power operated from the touch screen arduino, the heater, the engine of the metering, etc ..
if I could not do so or whether to add something else.
I attached circuit relay
Thanks in advance
Post Number:#2 Post Fri Mar 25, 2016 3:24 pm
If your relay board work with 12V the wiring is like this:
Post Number:#3 Post Fri Mar 25, 2016 5:46 pm
OK Fernando understand that this relay works with 12v and not with 5v as I have connected and from the lcd modify the temperature I found this circuit to connect multiple devices, you think this may be worth not have to change anything to me in bookstores
Thanks again
-------------------------------- Last edited Fri Mar 25, 2016 6:58 pm --------------------------------
by the way of the image display overrides that you sent me interested in electric installation for connection of devices and control 220v with jarduino :D :D
Post Number:#4 Post Fri Mar 25, 2016 6:07 pm
I have no idea about what you want show with this schematic.
Post Number:#5 Post Sat Mar 26, 2016 1:21 pm
I just wanted to know if the connection is correct for the connection of electrical appliances 220v relay module with this so well and can connect from ferduino lcd
Post Number:#6 Post Sat Mar 26, 2016 2:07 pm
The wiring for AC load is like this:
Post Number:#7 Post Sat Apr 02, 2016 6:21 am
Hello Fernando sorry for late reply I have had problems already solved hospital
Thanks to all for the contribution, but you tell me how I use the timer from ferduino for more I try not achievement that led to the relays as they are running as connect as turn on you told me on pin 42, Arduino me on but does not trigger the relay to turn on my water heater
Thanks again
#-o
-------------------------------- Last edited Sat Apr 02, 2016 7:50 am --------------------------------
Fernando forgive and I have solved I found a short circuit and it works thanks :D :D :D
Users viewing this topic: DotBot [Bot] and 1 guest
