Forum Hardware Others components TFT 5"
TFT 5"
Post Number:#2 Post Fri Feb 14, 2020 11:17 am
Images: 280
Solve rating: 220
Yes, but you should make the changes explained here.
Moreover you have to edit the code to make the menu fill all the screen. All versions modified by users available on forum for 800x480 screen are outdated.
Please do not PM me for support unless it is absolutely necessary.
I'll not write custom function to nobody unless you can pay for my job.
Post Number:#3 Post Fri Feb 14, 2020 12:56 pm
Germany
Post Number:#4 Post Fri Feb 14, 2020 1:16 pm
Images: 280
Solve rating: 220
You should ask the datasheet for this seller because the backlight for this big screens normally are 5 V.
Post Number:#5 Post Fri Feb 14, 2020 4:04 pm
Germany
I found this https://ecksteinimg.de/Datasheet/CP11009.zip
but found nothing about this.
with touchscreen
Display: 5.0 "TFT with backlight
Color spectrum: 262K
Backlight: LED
Resolution: 800 x 480
IC driver: SSD19635V / 3.3V TTL logic compatible.
The display can be used directly in the 5V / 3.3V Arduino system.
Post Number:#6 Post Fri Feb 14, 2020 11:25 pm
Images: 280
Solve rating: 220
I'm not sure about it. The schematic seems different from PCB image.
Anyway you can try connect directly and if the backlight has low brightness so you can make the changes above.
Post Number:#7 Post Mon Apr 27, 2020 3:22 pm
Images: 280
Solve rating: 220
Any news here?
Return to Others components
