Forum Hardware Others components Suggestions about feeder
Suggestions about feeder  [SOLVED]
Post Number:#1 Post Sat Feb 10, 2018 2:57 pm
Images: 8
I would like to use the Feeder feature which is very convenient for switching off the pumps.
I have a doubt about the choice of the automatic feeder.
could you recommend a model that performs well the function commanded by ferduino?
Post Number:#2 Post Sat Feb 10, 2018 5:17 pm
Any model with switch button to manual feed can work with Ferduino.
Post Number:#3 Post Sat Feb 10, 2018 8:07 pm
Images: 8
Perfect. Thank you.
But how does it connect to the ferduino?
I have connected the pin that commands the Feeder to the relay and when push the Button "Feed now" the relay turns on for one second.
I believe this is not the right connection.
Thank you for your help
Post Number:#4 Post Sat Feb 10, 2018 9:09 pm
Connect the relay in parallel with switch button for manual feed.
If the time configured is 1s it's ok.
Post Number:#5 Post Mon Feb 12, 2018 10:22 am
Images: 8
thank you. it works perfectly
Return to Others components
