Hi Fernando and all,
I bought an electronic return pump, the Tunze 1073.050.
Here you can find the manual with details:
https://www.tunze.com/fileadmin/gebrauc ... 3.0588.pdf
it has a power supply with an output at 24V DC 3A that goes into a controller that you can see here:
https://www.tunze.com/PT/en/products/de ... D=7090.250
I would like to use the wave maker output of Ferduino to control this pump.
I'm pretty sure that I should connect the wavemaker output to something in the controller...but I don't have the minimum idea of how.
On the controller there is a potentiometer, so probably the connection should be made to its pins.
Can somebody help me in understanding how can i do this simple thing?
thank you so much, as usual.
