Forum Hardware Others components Connectors for level and temperature sensors, relays board f
Connectors for level and temperature sensors, relays board f  [SOLVED]
Hi guys!
I'm happy to become part of this fantastic community. I think that Fernando and the whole team did a great job!
I'm designing a new aquarium and I would like that Ferduino will be the real beating heart of the whole system.
If I found out a used controller... I will need to realize some connections.
Let's start from a relays board. This one could be ok?
https://www.plexishop.it/it/modulo-rele-16-canali.html
Using that one, what i should do will be justo to buy something like this:
https://it.aliexpress.com/item/D-SUB-DB ... a4a452f934
and perform right connection on the DB25 connector? that's right?
for temperature sensor, can i buy a AS18B20 classic sensor and buy this one for connecting sensor to Ferduino?
https://www.plexishop.it/it/adattatore- ... -vite.html
Finally, for level sensor, is this one ok?
https://www.plexishop.it/it/sensore-di- ... quidi.html
which kind of connector there is on Ferduino for level sensor? which adapter can I buy for making the connection between sensors and board easy as Fernando thought?
thank you so much!
Welcome Thomas!
Before starting building your controller check all Ferduino Mega documentation available on forum.
Your questions were answered before here.
Take a look at:
viewtopic.php?f=6&t=100
http://ferduino.com/wp-content/uploads/ ... PinMap.pdf
viewtopic.php?f=10&t=162
Connect the level sensors wires directly to mono jack phone. There only two points to connect wire on connector and the polarity doesn't matter.
Connect the temperature sensors wires directly to mono jack phone. Follow the schematic.
Ok. Got it. Thank you so much!
Return to Others components
