Forum Members section Show your controller My build.
My build.
Post Number:#1 Post Mon Jan 12, 2015 3:24 pm
Topics: 12
Topics: 12
Netherlands
In this topic I will try to post my progress on my build of the ferduino. I just ordered all the goodies so the waiting game begins :) .
-------------------------------- Last edited Mon Jan 12, 2015 4:31 pm --------------------------------
What affordable relay do you guys reccomend if i want to be able to switch some 220v pumps on. And some 12v fans? Ebay of dealextreme link would be awesome.
Post Number:#2 Post Tue Jan 13, 2015 12:23 pm
Images and links for parts are available here: viewtopic.php?f=24&t=39
If you have doubt about max. current, you can look this post: viewtopic.php?f=18&t=115&start=60
Post Number:#3 Post Tue Jan 27, 2015 10:13 am
Topics: 12
Topics: 12
Netherlands
I am having issues uploading the code. I am trying to upload the web server based code. But I get these errors:
A_English.ino:74:1: error: 'prog_char' does not name a type
A_English.ino:75:1: error: 'prog_char' does not name a type
A_English.ino:76:1: error: 'prog_char' does not name a type
A_English.ino:77:1: error: 'prog_char' does not name a type
Last edited by Fernando Garcia on Tue Jan 27, 2015 11:42 am, edited 1 time in total.
Reason: Please use tags [code] [/code] to post any code here.
Post Number:#4 Post Tue Jan 27, 2015 10:50 am
Use the IDE 1.0.6.
Post Number:#5 Post Tue Jan 27, 2015 11:50 am
Topics: 12
Topics: 12
Netherlands
That fixed the uploading problem. Now my next challenge is to get the touchsreen working. I can upload the calibration code and i get the "touch screen to continue" screen. But when i touch the screen nothing happens. Als with button programm no reaction to the screen. I have bought the recommended screan from itead.
Post Number:#6 Post Tue Jan 27, 2015 11:54 am
Post Number:#7 Post Tue Jan 27, 2015 12:07 pm
Topics: 12
Topics: 12
Netherlands
Post Number:#8 Post Tue Jan 27, 2015 5:48 pm
Topics: 12
Topics: 12
Netherlands
is there a way to test the ethernet module? when i do the http://192.168.0.250:7000/?cmd=blablabalabl==,0,k after a fresh rebout in the first 10 secs it will give me a good response. After the 10 seconds it will only tim out and no longer response. Any ideas?
Post Number:#9 Post Tue Jan 27, 2015 7:25 pm
Topics: 12
Topics: 12
Netherlands
I can ping it no problem there. I am now trying at port 7000 but not luck.
-------------------------------- Last edited Tue Jan 27, 2015 8:49 pm --------------------------------
I am now trying to run the web server test code at 192.168.0.177. And i get this result:
server is at 0.0.0.0
Initializing SD card...
SUCCESS - SD card initialized.
SUCCESS - Found index.htm file.
But 192.168.0.177 is pingable, so I am stumped.
Post Number:#10 Post Tue Jan 27, 2015 7:52 pm
You are using a SD card of 1 or 2 GB?
Post Number:#11 Post Wed Jan 28, 2015 5:07 am
Topics: 12
Topics: 12
Netherlands
Post Number:#12 Post Wed Jan 28, 2015 6:12 am
Topics: 12
Topics: 12
Netherlands
SUCCES :ymparty: :ymparty: :ymparty: :ymparty: :ymparty: :ymparty: :ymparty: :ymparty:
After throwing away the ethernet library and recopying it. It is now working the way it should. What an awesome computer. Thank you Fernando for all your help.
I was too early, had it working exact one time now. Now again it is not working. At least i now know it can work. So back to troubleshooting again :)
-------------------------------- Last edited Wed Jan 28, 2015 7:49 am --------------------------------
If i test the response of the board. I get the right response right after it boots (1 sec after display goes on). Then later no response. Then reset response within 1 sec and later then 1 sec no more response. Tried 2 different sd-cards.
-------------------------------- Last edited Wed Jan 28, 2015 8:08 am --------------------------------
It seems i am getting somewhere. After trying my third sd-card it started working again. So the issue seems to be sd-card related. What are the exact specs for the sd to qualify?
Post Number:#13 Post Wed Jan 28, 2015 7:17 am
Try add a shunt on TFT as I told here: viewtopic.php?p=1377#p1377
Post Number:#14 Post Wed Jan 28, 2015 8:40 am
Topics: 12
Topics: 12
Netherlands
Post Number:#15 Post Wed Jan 28, 2015 9:02 am
This model have a pad called J1.
Post Number:#16 Post Wed Jan 28, 2015 9:29 am
Topics: 12
Topics: 12
Netherlands
Post Number:#17 Post Wed Jan 28, 2015 9:32 am
Post Number:#18 Post Wed Jan 28, 2015 7:53 pm
also double check your power at the shield, I was getting low voltage to the TFT all together I now use VIN from db25 with 6 volts and it works every time.
Post Number:#19 Post Mon Feb 02, 2015 6:11 am
Topics: 12
Topics: 12
Netherlands
i have mine working now the way it want :) . I use the water temp for temperature of my sump. led temp for the temperature in my aquarium and ambient for ambient. I als build a floatswitch that get's triggered if my return pump fails. I adjusted the code so that when that happen my reactor ph reads 25 so that i can use the reactor pH alert of joy reef to see if my return pump is still functioning :) . Now all for me left to build is a nice fan with relay to cool in the summer. And i am still thinking on how to build something to see if my streamer is still active. I actually sold my profilux system beceause i like the ferduino much more.
Should i better use a ssr of a normal relay to switch a 12v fan?
Post Number:#20 Post Mon Feb 02, 2015 6:56 am
Glad to hear.
To a fan untill 500 mA an ULN2003 is enough.
