Forum Members section Show your controller My Ferduino DIY
My Ferduino DIY
Post Number:#21 Post Mon May 04, 2015 11:42 pm
Post Number:#22 Post Tue May 05, 2015 3:48 am
Belgium
Post Number:#23 Post Tue May 05, 2015 12:47 pm
Jean thanks for the link that program looks like fun to use I really like all the boxes you found for every thing almost like they where made for parts
Post Number:#24 Post Tue May 05, 2015 4:14 pm
Post Number:#25 Post Tue May 05, 2015 5:21 pm
Belgium
Hello Christopher,Dale,
I only buy 2 boxes and I must admit that I had some luck because when you order from the net you don't know exactly what you will get.For the "Stamps box" I had no problem but for the "relay box" I had to rework it and until I finished all the wiring I was not sure that I would be able to close it.
As I said,dosing pump box was made from electrical trunking so really easy to do (most difficult is to adjust the 2 plastic side) .
The main box for Ferduino has been made by a friend following the dimensions that I gave.
After I had to do all the openings in accordance with my shield.
Finally the look comes from the adhesive that was put on the different boxes.
I am sure that your final work will also look amazing.
The main problem is to find time .
Best regards,
Jean-Yves
Post Number:#26 Post Sat Apr 13, 2019 2:12 pm
Images: 280
Solve rating: 220
Hi Jean!
Some users has problems with this PCF module. Can you show us the schematic of your board?
You had some problem with your relay board as relay not being activated just the LED light up slightly?
Please do not PM me for support unless it is absolutely necessary.
I'll not write custom function to nobody unless you can pay for my job.
Post Number:#27 Post Sat Jun 27, 2020 10:21 pm
Has this been resolved?
If not I may have some ideas.
In my case it was a current issue as soon as I moved the relay board to it's own power supply it solved my issue.
Post Number:#28 Post Mon Jun 29, 2020 12:28 pm
Images: 280
Solve rating: 220
Hi Christopher!
The problem was due a difference of behaviour between PCF8575TS and PCF8575C.
You can see all conversation here.
