Post Number:#341 Post Sun Dec 11, 2016 3:50 pm
Post Number:#342 Post Sun Dec 11, 2016 5:24 pm
I found a missing part in setup:
pwm.begin();
pwm.setPWMFreq(1600);
-------------------------------- Last edited Sun Dec 11, 2016 3:13 pm --------------------------------
all wavemaker functions are working with ferduino and web control through PCA9685 board using I2c communication, next to build a menu for control of the return and protein skimmer pumps so they can all be put on the same power supply. yay less wall outlets used.
Post Number:#343 Post Mon Dec 12, 2016 7:16 am
I see this line but I think there a default value, so this line is not mandatory but I'm not sure.
Post Number:#344 Post Mon Dec 12, 2016 8:55 am
Pump did not run without it so I added it and pumps were running.
-------------------------------- Last edited Mon Dec 12, 2016 6:07 am --------------------------------
If I am correct it is the communication to tell the PCA how fast to run in hertz frequency, I believe 1600 is the max speed that it will process.
Post Number:#345 Post Mon Dec 12, 2016 9:10 am
Yes, the library haven't a default value declared for frequency.
https://github.com/adafruit/Adafruit-PW ... iver.h#L51
Post Number:#346 Post Sun Jan 08, 2017 12:01 am
Last 2 ISO boards are done, If you you want one PM me.
-------------------------------- Last edited Sat Jan 07, 2017 9:10 pm --------------------------------
Post Number:#347 Post Wed Feb 21, 2018 8:34 pm
Hi Fernando I am working with theold board again and can not get the screen to come up I used this from a long time back and checked all pins
as shown, on the 20x2 all pins have a reading of 4.2 volts and on the others pins 6 and 7 have no voltage any thoughts?
update never mind it is okay now found a bad connection.
Using the code below try:
1º Check if have ~ 4.5 V on pins 3 - 7, 22 - 41 and 50 - 53;
2º Check if have ~ 3.3 V in all pins else to GND and NC on connector 2 x 20.
Image: http://ferduino.com/forum/gallery/image.php?album_id=11&image_id=132
  for(int i = 3; i < 8; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, HIGH);
  for(int i = 22; i < 42; i++)
    pinMode(i, OUTPUT);
  for(int i = 50; i < 54; i++)
    pinMode(i, OUTPUT);
Users viewing this topic: AhrefsBot [Bot] and 2 guests
