Forum Members section Show your controller Real amateur Build.
Real amateur Build.
Post Number:#81 Post Thu Jul 20, 2017 11:23 am
Images: 13
Greece
Thank you both for the answers!!
I also noticed that when chiller is off and water level indicator saws always low. when the chiller is on the water level indicator works fine.
Best Regards.
Post Number:#82 Post Thu Jul 20, 2017 12:41 pm
The level status is not related with chiller status.
Check the function "void check_nivel()" to see the conditions.
If sensors 1, 2, 4, 5 and 6 are not connected you will get random status.
If you don't want connect this sensors put fake pin numbers on code.
Post Number:#83 Post Fri Aug 04, 2017 11:08 pm
Images: 13
Greece
Post Number:#84 Post Sat Aug 05, 2017 9:40 am
Doesn't matter since the GND from both power supplies are interconnected.
Post Number:#85 Post Sat Aug 26, 2017 9:17 am
Images: 13
Greece
Hi.
I have a question regarding moonlight. The moonlight is always on and quite bright even when there's new moon and new moon light brighteners is set to 0. Is it normal? How can i change it to start from zero lighting in new moon to max lighting in full moon?
Best Regards.
Post Number:#86 Post Sat Aug 26, 2017 9:46 am
Not, the power should be according to settings in moonlight menu.
Example:
In this case the PWM in new moon should be 40 and in full moon 255.
Post Number:#87 Post Sun Aug 27, 2017 6:29 am
Images: 13
Greece
Example:
Image: https://farm9.staticflickr.com/8489/8267317163_5c1b038d43_b.jpg
Hi.
According the photo above, if the Lua Nova is set to zero there must be no moonlight at all, right? In my case it is quite bright.
Best Regards.
Post Number:#88 Post Sun Aug 27, 2017 8:13 pm
Check the voltage on PWM pin maybe your driver has inverted logic. In other words 0V to 100% and 5V to 0%.
Post Number:#89 Post Wed Sep 06, 2017 2:40 pm
Images: 13
Greece
Post Number:#90 Post Thu Sep 07, 2017 12:58 am
A quick question please. I have free 16,17,20,21 pins. I don't use PCF8575 or ESP8266. Can i use them for dosing pumps?
Best Regards.
Yes, obviously.
Users viewing this topic: No registered users and 6 guests
