Forum Members section Show your controller My build.
My build.
Post Number:#61 Post Mon Mar 02, 2015 5:55 am
Topics: 12
Topics: 12
Netherlands
I am having a small issue with my new ph stamp code. Since i run this code I see that joy reef is having issues with retreiving the data from my ferduino. I guess it is because of the duration it takes to fullfill the 21 reading. Any hints for improving this?
void check_parametro_ph_aquario()
  char inData[150];
  char *inParse[150];
  int index = 0;
  int contador = 0;
  boolean stringComplete = false;
  char *str;
  int count = 0;
  Open_channel(ph1);
  delay(50);
  Serial3.print("T,");
  Serial3.print(tempC);
  Serial3.print('\r');
  do
    if (Serial3.available()>3)
      char inChar = Serial3.read();
      inData[index] = inChar;
      index++;
      if (inChar == '\r')
        contador ++;
      if(contador == 23)
        inData[index] = '\0';
        contador = 0;
        stringComplete = true;
  while(stringComplete == false);
  for (int i= 0; i <= index; i++)
    if (inData[i] == '\r')
      inData[i] = ',';
  char *p = inData;
  if (stringComplete == true)
    while ((str = strtok_r(p, ",", &p)) != NULL)
      inParse[count] = str;
      count++;
    PHA = 0;
    for(int i= 13; i < 21; i++) //13
      PHA += atof(inParse[i]);
    PHA /= 8; //8
Post Number:#62 Post Mon Mar 02, 2015 9:21 am
Which interval do you have to update the pH?
Changed this line on loop?
if((millis() - millis_antes) >= 120000)
Post Number:#63 Post Mon Mar 02, 2015 9:46 am
Topics: 12
Topics: 12
Netherlands
Post Number:#64 Post Mon Mar 02, 2015 9:57 am
Add this lines to check how many time is needed to update the pH.
After:
int count = 0;
Add:
unsigned long time = millis();
After:
   PHA /= 8; //8
Add:
Serial.print("Time: ");
Serial.println(millis() - time);
Post Number:#65 Post Tue May 19, 2015 9:39 am
Topics: 12
Topics: 12
Netherlands
