New build.
Post Number:#61 Post Mon Nov 24, 2014 2:57 pm
I have an observation for you.
This is my relay board:
As you can see the specification says 125 V / 10 A but, look the PCB trace width:
The width is 3 mm, using this calculator the maximum load for this width is 5.3A.
So no matter if the relay can work at 10 A if the PCB trace can't.
Post Number:#62 Post Tue Nov 25, 2014 6:59 pm
Hi, the new relays that I just got have a thicker and wider trace than the others, I asked before I bought them. trace is 5.5mm wide and 2.5oz thick. thank you for the info and, could you post a link to the calculator you showed?
Post Number:#63 Post Tue Dec 02, 2014 3:37 pm
Go here:
Image: http://screenshots.portforward.com/routers/Dlink/DIR-815/Advanced_Port_Forwarding.jpg
In the first row:
IP Address: (ip you set in ferduino code)
Public port and private port: choose the port you set in Ferduino Mega code
In joy-reef in ip address put the addres you get from the ? in the field.
This should work, let us know
this did not work I have gone back to the d-link router and my own modem.
Post Number:#64 Post Tue Dec 16, 2014 12:00 am
So new weird issue ferduino board working and online now, thank you so very much for the help Fernando, I have a new issue the ferduino kicked all most all other items off my home network but i will figure that one out.
-------------------------------- Last edited Mon Dec 15, 2014 9:00 pm --------------------------------
Post Number:#65 Post Tue Dec 16, 2014 3:51 am
I have figured out what happend on my network, it was something I forgot to change #-o .
Next part will be to set up 16 relay board 120 volt items and controls as well as codde for PCF. :D
-------------------------------- Last edited Tue Dec 16, 2014 1:11 am --------------------------------
Post Number:#66 Post Thu Dec 18, 2014 3:38 am
Ok so new issue was working on some other stuff and now no more Internet connection, when I bring up the serial monitor it give a server ip of 198.128.0.128 whitch is not the server I have it set up for I tried to reboot router and network, then I tried to change port on all three ferduino, router and, joy reef but none worked. I work more with it tomorrow.
I did however have a question about the pins for the chiller and heater I could not PCF8575 to work so I went back to original and was wondering is on when pin is LOW or HIGH?
-------------------------------- Last edited Thu Dec 18, 2014 1:02 am --------------------------------
Post Number:#67 Post Thu Dec 18, 2014 8:31 am
This issue of wrong IP is related with SD card. Check if your card is connected and working fine.
Your relay board should be HIGH to OFF and LOW to ON.
On this case I think better connect the relay board to an ULN2803 so, no needs lose time changing the code.
Wiring:
Post Number:#68 Post Thu Dec 18, 2014 10:20 am
The ULN chip is all redy on the board or do I have to set up?
Ip issue: I will check the sd card when I get home, serial said it was reading ok but that may not be the case?
How hard would it be to add more buttons to menu 2 for service of pumps to turn off, on and automatic.
As far as pump controls I will try that on my own I am not trying to make more work for you. :-bd
Post Number:#69 Post Thu Dec 18, 2014 2:29 pm
ULN can be used when relays are connected to RJ45 (Relays-1) or you can change on code HIGH to LOW and LOW to HIGH.
This isn't needed when the relays are connected to DB25.
The difficult depends of your ability to learn.
I did a new example, check this topic.
Post Number:#70 Post Sat Dec 20, 2014 4:47 pm
I tried the code change for db25 and was not able to get it to work, one question is does the pin configuration stay the same as in you previous post or do all pins become high low switched?
Post Number:#71 Post Sat Dec 20, 2014 5:13 pm
To DB25 NO need change LOW to HIGH.
First try using this example to make sure that it isn't a problem of wiring.
#include <Wire.h>
#include <PCF8575.h>
byte address = 0x20;
PCF8575 PCF8575;
  Serial.begin(38400);
  Serial.println("I'm alive!");
  PCF8575.begin(address);
  for(int i = 0; i < 16; i++)
    PCF8575.pinMode(i,OUTPUT);
    PCF8575.digitalWrite(i, HIGH); // Tun on all pins
    delay(200);
  delay(5000);
    PCF8575.digitalWrite(i, LOW); // Turn off all pins
    delay(200);
  delay(5000);
Post Number:#72 Post Sat Dec 20, 2014 6:36 pm
Post Number:#73 Post Mon Dec 22, 2014 9:06 am
Hi Fernando.
I was able to get the test code that you gave me for PFC8575 to work now I just need to assiggn the pins, I had seen in an other post here you showed how to assign the pins I just remember witch one. Can you repost for me.
-------------------------------- Last edited Mon Dec 22, 2014 6:51 am --------------------------------
Hi Fernando.
Post Number:#74 Post Tue Dec 23, 2014 3:07 pm
Hi Fernando.
Just was wondering how you and Willie changed things for his 5.0 TFT? I have been looking all over the place and can't find any thing. Also how can I shift all C readings to F on all pages, I have figured some out. plus on that same topic when I changed code as shown in Willie's feed I now get high temp alarms.
Post Number:#75 Post Tue Dec 23, 2014 3:47 pm
Post Number:#76 Post Wed Dec 24, 2014 11:25 pm
relays all worked on time I have working with the code to try and get them to work as they should and can't them to come on. then some thing new came up I loaded the test code that you gave to me the other day and none of them would work, so disconnect all but one and the light baerly came on the relay board is hooked to a power supply from a pc and, ferduino is on usb power not sure what to do next. really bummed out at this point. and joy reef is hit and miss weather it will work as well. :-s :| :-\
Post Number:#77 Post Thu Dec 25, 2014 9:47 am
Have you connected GND from Ferduino Mega to GND in the relay board?
Look for this:
Post Number:#78 Post Fri Dec 26, 2014 7:42 pm
when I tried to supply power with Ferduino board it did not work so I was using pc power supply to power 5 volts on the relay board.
Now it is all working again?
Post Number:#79 Post Fri Dec 26, 2014 8:21 pm
Post Number:#80 Post Fri Dec 26, 2014 9:23 pm
i am not sure what happened but the other night only the lights on the relay board would come on and the relays would not click, but now all is working again, nothing is connected any different so I am not sure what to do some things are not being reliable and it has me very nervous to put on my tank
PreviousNext
