Forum Members section Show your controller Real amateur Build.
Real amateur Build.
Post Number:#41 Post Wed Jun 14, 2017 6:05 pm
Images: 13
Greece
Hi Fernando.
I have a problem regarding led fans. I have 2 wire fans for my leds and i followed the schematic to connect them to ferduino but the fans doesn't turn on. I double checked the wiring and seems ok. What is possible went wrong?
Best Regards
Post Number:#42 Post Wed Jun 14, 2017 7:20 pm
Comment this line:
#define DEBUG
Post Number:#43 Post Fri Jun 16, 2017 5:24 pm
Images: 13
Greece
Comment this line:
#define DEBUG
Hi, The line is commented. The fans seems to have power, cause the leds they have on it lit up, but they don't start.
-------------------------------- Last edited Fri Jun 16, 2017 11:58 pm --------------------------------
Comment this line:
#define DEBUG
Hi.
I solved the power problem, but fans don't turn off when the temperature is below limit or the leds are turn off.
Post Number:#44 Post Fri Jun 16, 2017 8:04 pm
Post Number:#45 Post Fri Jun 16, 2017 10:09 pm
Images: 13
Greece
Post Number:#46 Post Fri Jun 16, 2017 10:40 pm
It doesn't helps.
Unplug disable pin from Arduino and plug on 5V directly. It should turn on the fan otherwise there some error on circuit.
Post Number:#47 Post Sat Jun 17, 2017 11:22 am
Images: 13
Greece
It doesn't helps.
I noticed that yesterday the fans didn't stop, now don't start. I plugged the disable pin directly to 5V but the fan didn't start. The only way to turn on the is to plug the fan GRD directly to power GRD.
Post Number:#48 Post Sat Jun 17, 2017 12:05 pm
So replace your ULN and double check the circuit.
Assembly it in a breadboard to test before make the PCB.
Post Number:#49 Post Sat Jun 17, 2017 1:27 pm
Images: 13
Greece
I Used a new one ULN2003 with a breadboard. The result was the same.
Post Number:#50 Post Sat Jun 17, 2017 4:27 pm
What's the max. current of your fan?
Post Number:#51 Post Sat Jun 17, 2017 7:12 pm
Images: 13
Greece
Product parameter:
Product size: 193 (L) * 113 (W) * 66 (H) mm
Material: aluminum fin +4pcs Ø 6mm heat pipe
Fan size: 92 x 92 x 25 mm x 2pcs
Fan connector: 3pin
Fan speed: 2000 RPM ± 10%
Air flow: 85 CFM
Bearing type: Hydraumatic (hydraulic)
Noise: 25 dBA ± 10%
Rated voltage: 12 VDC
Rated current: 0.17 ± 0.02 A
Service life: 40000 Hours
Weight: 430g
Post Number:#52 Post Sat Jun 17, 2017 7:48 pm
Try some old PC fan, the problem can be this model of fan.
The circuit should work without connect to Arduino.
Post Number:#53 Post Sat Jun 17, 2017 10:47 pm
Images: 13
Greece
I used an old fan i have. The fan turns on but stays always on. When i disconnect the disable pin the fan turns off.
Post Number:#54 Post Sun Jun 18, 2017 10:38 am
Always ON when disable pin is connected to Arduino?
Check temperature settings in your controller and disable debug messages.
Try another free pin for disable the fan.
Post Number:#55 Post Sun Jun 18, 2017 12:29 pm
Images: 13
Greece
It's always on. I start at 28c when the room temp is 26. When i remove the disable pin, or turn off arduino it turns off. I tried a different disable pin, but it acts the same. Where can i disable debug messages?
Best Regards.
Post Number:#56 Post Sun Jun 18, 2017 3:06 pm
I told it before.
#define DEBUG
Why are you using room temperature as reference? Fans are controlled by heatsink temperature.
The code to control this pin is very simple there no reason for errors. Look for "Parametros" tab.
  if (tempH < HtempMin)
    myDigitalWrite(desativarFanPin, LOW);
    myDigitalWrite(desativarFanPin, HIGH);
If you are using a different pin than RX and TX you can enable debug messages.
Post Number:#57 Post Sun Jun 18, 2017 8:17 pm
Images: 13
Greece
I told it before.
#define DEBUG
Sorry, i meant heatsink temperature. I already checked the debug line and it was commented. The if statement it is also correct.
I also noticed that the 4 fans current together is to much for one ULN2003pin. For one fan it works well till now. To turn on all other fans do i have to use a new ULN2003 for each fan or just another pin on the same ULN2003?
I also installed the moonlight. The led lights never turn off is it normal?
I am a heart beat away from installing my led system but i don't want the fans to be turned on 24/7. So any other suggestion would be appreciated.
Best Regards.
Post Number:#58 Post Sun Jun 18, 2017 10:07 pm
It's so bad to hear because in circuit page there two images showing the wiring and is very clear the information of 500 mA per fan (in other words per pin). Moreover I asked about current.
In the first image you can see F1, F2.... F7. It mean a fan to each pin, total 7 fans per ULN.
Yes.
Post Number:#59 Post Mon Jun 19, 2017 2:44 pm
Images: 13
Greece
I changed my arduino cause i suspected problems. My old one is not recognized by pc any more. With new arduino i have new problems. When DS3231 is on the program can't start and the display stays black. When i remove it, the program starts normally. With old arduino it worked fine. I run the RTC test code and works fine. Is there something to check?
Best Regards
Post Number:#60 Post Tue Jun 20, 2017 10:31 am
Can be many things, bad contact, bad Arduino pins and etc.
Try change the pins for RTC to 18 -19 or 20 -21.
PreviousNext
Users viewing this topic: No registered users and 6 guests
