New build.
Post Number:#41 Post Fri Nov 07, 2014 8:23 am
You saw this topic?
The jumper "F" is unplugged?
Post Number:#42 Post Fri Nov 07, 2014 2:13 pm
It is now this is the first time I have had to unplug it, also if I remove and bridge pfc8575 do I still have switching function on relay board?
-------------------------------- Last edited Fri Nov 07, 2014 10:13 am --------------------------------
Post Number:#43 Post Fri Nov 07, 2014 2:24 pm
Can you make upload now?
You need change the code for PCF8575 anyway.
Which model of relay board you have?
Post Number:#44 Post Fri Nov 07, 2014 7:23 pm
yes can upload but now no buzzer for alarm, as far as relay board I will try to find more info, thank you again for your help sir.
Post Number:#45 Post Fri Nov 07, 2014 7:32 pm
While you don't need make upload the jumper can be plugged. ;)
Post Number:#46 Post Fri Nov 07, 2014 7:43 pm
ebay page for relay board
this the board that I bought.
By the way I have my temp sensors know which post showed to convert to Fahrenheit from Celsius?
Last edited by Christopher Kindig on Fri Nov 07, 2014 8:17 pm, edited 1 time in total.
Post Number:#47 Post Fri Nov 07, 2014 8:10 pm
This relay board no need of bridges on ULN2803.
Post Number:#48 Post Sat Nov 08, 2014 9:30 am
Post Number:#49 Post Mon Nov 10, 2014 7:17 am
Thanks again Fernando, is there a screen I can add or is already done that I can have manual control of all relays or do I have to write new code to get all function individual?
-------------------------------- Last edited Mon Nov 10, 2014 3:37 am --------------------------------
Post Number:#50 Post Mon Nov 10, 2014 8:54 am
This function doesn't exist in my code.
Post Number:#51 Post Mon Nov 17, 2014 7:30 pm
Can you show us some images of your build?
Post Number:#52 Post Mon Nov 17, 2014 7:58 pm
this is the latest. :D
-------------------------------- Last edited Mon Nov 17, 2014 4:16 pm --------------------------------
plug with straight in connectors. :D
Post Number:#53 Post Mon Nov 17, 2014 8:20 pm
What's the length of this cable?
What's the model of this connector on TFT?
Post Number:#54 Post Tue Nov 18, 2014 1:05 am
cable is 10 foot and, I made the connector using DuPont headers and pins.
I have run into some issues with joyreef, my router is d-link DIR-815 and I can't get it to setup as yours is for web control. any ideas? ~x(
Post Number:#55 Post Tue Nov 18, 2014 8:47 am
Wow 300 cm!
This enclosure will stay away saltwater, right? I'm worried with oxidation.
You're talking about port forwarding?
It works with local IP? Check this post.
Post Number:#56 Post Tue Nov 18, 2014 7:43 pm
Images: 1
Go here:
In the first row:
IP Address: (ip you set in ferduino code)
Public port and private port: choose the port you set in Ferduino Mega code
In joy-reef in ip address put the addres you get from the ? in the field.
This should work, let us know
Post Number:#57 Post Wed Nov 19, 2014 4:32 pm
the tower will be in another part of my stand away from the water.
-------------------------------- Last edited Wed Nov 19, 2014 1:11 pm --------------------------------
this my tank and stand, the tower will go on the right side
Last edited by Fernando Garcia on Wed Nov 19, 2014 5:26 pm, edited 1 time in total.
Reason: Image fixed.
Post Number:#58 Post Mon Nov 24, 2014 1:12 am
Ok so here it is, the d-link router is gone I have only the comcast provided router and I can not get the port forward to work. I can ping with "cmd" from windows and get a return I have every witch way for over a week now to get the joy-reef app and it is not working for me, I think I am missing something or to many steps I'm not sure.
-------------------------------- Last edited Sun Nov 23, 2014 9:20 pm --------------------------------
new high amp relays for big power items. (reeflow pump and 2, 300 watt heaters)
Post Number:#59 Post Mon Nov 24, 2014 9:40 am
For Chiller and heater SSR is better. ;)
P.S. You're using wrong link to post images from gallery. Use the "Image-URL:" instead "Image BBCode:".
Post Number:#60 Post Mon Nov 24, 2014 2:19 pm
Hi! most ssr only have 2 amp load rating reeflow pump runs at 2-6 amps constant. same with 300 watt heaters. I am having no luck with joy-reef ferduino. even called ISP to ask for help. ~x(
PreviousNext
