Forum Members section Show your controller Willie's controller build
Post Number:#21 Post Sat May 31, 2014 1:21 pm
I never could figure out why my Chauvet controller was showing me a 2 degree difference from the Ferduino or my Neptune AC Jr. but I went in the code and subtracted the 2 degree difference so it displays the same temp as my other 2 now :)
It can be a problem if the difference isn't linear.
In other words with 79 ° F the difference can be of 2 °F.
But with 76 °F the difference can be of 0.5 °F.
Post Number:#22 Post Sat May 31, 2014 1:38 pm
^:)^ ^:)^ nice job is very difficult? change from 3.2 to 7? there a tutorial?
the home screen isn't too hard, but after looking at the rest of the code, I don't know is I will ever be able to change it, Fernando had to help me with the home screen, I changed too much stuff and had the LED bar graph kinda goofed up, Fernando found my issues and corrected me :)
going from 400 x 240 to 800 x 480 was just a matter of doubling the numerical coordinate values, simple as that, but knowing what were coordinates and what wasn't was my problem :)
-------------------------------- Last edited May 31st, 2014, 11:01 am --------------------------------
Jarduino use resolution of 9 bit's and Ferduino use of 10 bit's.
See the datasheet of the sensor:
DS18B20
The core functionality of the DS18B20 is its direct -to-digital temperature sensor.
The resolution of the temperature sensor is user-configurable to 9, 10, 11, or 12 bits, corresponding to increments of 0.5°C, 0.25°C, 0.125°C, and 0.0625°C, respectively.
Moreover Ferduino use an average of 12 values.
High precision. :D
I was just playing with the numbers to see what happened, I'm still trying to figure this stuff out :) I really don't understand all the data on the temp probes but I know they are extremely accurate....
I never could figure out why my Chauvet controller was showing me a 2 degree difference from the Ferduino or my Neptune AC Jr. but I went in the code and subtracted the 2 degree difference so it displays the same temp as my other 2 now :)[/quoteI
do not know where you would like to share the code? ~x( ~x(
sngianluca@gimail.com
Post Number:#23 Post Sat May 31, 2014 2:24 pm
Post Number:#24 Post Sun Jun 01, 2014 5:00 am
Now thats funny - as I did it a completely different way!
I changed all instances of sensors.getTempC to sensors.getTempF and then updated the ranges on the menus.
Post Number:#25 Post Sun Jun 01, 2014 12:11 pm
I not seen this option.
I seen this on example:
DallasTemperature::toFahrenheit(tempC); // Converts tempC to Fahrenheit
I think that it was more simple.
tempC = (tempC * 1.8) + 32;
Willie not forget this detail.
https://github.com/FernandoGarcia/Fedui ... os.ino#L57
You need converter this values to Fahrenheit.
Post Number:#26 Post Sun Jun 01, 2014 1:50 pm
where is that in the code ?
Post Number:#27 Post Sun Jun 01, 2014 2:07 pm
See the name of the file on link.
Post Number:#28 Post Sun Jun 01, 2014 2:17 pm
what do I need to do there ? I'm not understanding :) something like this ?
  if ((tempC > 122) || (tempC <50))
     // ((tempC > 50) || (tempC <10))
    bitWrite(status_parametros,0,0);
    bitWrite(status_parametros,1,0);
Post Number:#29 Post Sun Jun 01, 2014 2:38 pm
Post Number:#30 Post Sun Jun 01, 2014 5:06 pm
Post Number:#31 Post Sun Jun 01, 2014 5:24 pm
Willie you're using the link wrong.
Use the "direct" link on photobucket.
Also use this tool to insert the image here.
This is the original size of your image.
Post Number:#32 Post Sun Jun 01, 2014 5:33 pm
OK thanks, I was using the IMG code and directly posting to the forum, that's how I always do it everywhere else, I'm still getting used to this forum but I like all the options :)
Post Number:#33 Post Sun Jun 01, 2014 5:50 pm
If you use only the tag [IMG] the maximum size will be 800 x 600 pixels.
If you use the tag [IMG=LEFT] the maximum size will be 1280 x 1024 pixels.
:-bd
Post Number:#34 Post Sun Jun 01, 2014 6:36 pm
Post Number:#35 Post Mon Jun 02, 2014 6:17 am
problem to the touch
worked perfectly with sheld CTE V1.15 but no clock
Then I tried the 1.1 sheld with clock screen was black did not work
now does not touch most 'be burned?
Post Number:#36 Post Mon Jun 02, 2014 8:02 am
I'm using this shield but both my shields like you posted work with mine too, not sure what could be wrong
http://www.ebay.com/itm/TFT-3-2-4-3-5-0 ... 1401528631
-------------------------------- Last edited Mon Jun 02, 2014 6:04 am --------------------------------
very good jobs to upscale at 7".
it's work perfect ?
I don't have it connected to my tank but I'm confident that it does work well, I just have the home screen up sized, I think I have the wavemaker screen and the temp probe screens both done too, as well as a lot of the menu buttons
Post Number:#37 Post Mon Jun 02, 2014 8:57 am
Willie, you have a SD card to test graphs?
You have an error on Graphs .
Now you have 40 pixels to each 2 hours.
https://github.com/willie111/Ferduino-7 ... os.ino#L54
So are 20 pixels to each 1 hour.
Each hour have 60 minutes.
60 / 20 = 3.
So you can use average of 3 values to each pixel.
https://github.com/willie111/Ferduino-7 ... s.ino#L181
Use:
    if (i == 3)
Last edited by Fernando Garcia on Mon Jun 02, 2014 9:25 am, edited 1 time in total.
Reason: Links fixed
Post Number:#38 Post Mon Jun 02, 2014 9:19 am
should it look like this ?
  for(int l=120; l<600; l+=40)
    myGLCD.drawLine(l, 60, l, 380);
    if (i == 3)
Post Number:#39 Post Mon Jun 02, 2014 9:26 am
Sorry, I had links inverted.
No, see line 181:
    if (i == 3)
      media = soma / k;
      i = 0;
      j++;
      soma = 0;
      k = 0;
Post Number:#40 Post Mon Jun 02, 2014 9:30 am
PreviousNext
Users viewing this topic: No registered users and 5 guests
